Coherence
Well it seems I just had to take apart the X-Ray to see what's inside, here's the scoop -
3 AA batteries, comes supplied w/ Energizer alkaline.
LOTS of empty space. There is a reason though, with lithium batteries the light floats, sinks with alkalines.
Circuit board (removed it). One 18 pin DIP chip, numbers sanded off! (I have heard of manufacturers doing this, just never seen it myself). Some SMT components, 4 white LED's and 1 blue LED that lights up in always on mode, and 3 microswitches.
Hooked it up to a regulated power supply, the circuit is stable at even at 2.3 volts, where the LED's are barely glowing at high setting. At 4.5v it draws 150mA, and is quite bright. As you adjust the voltage, the brightness varies across this range.
I'm going to put it back together, I like this light overall. I think you can make a case for buying lithiums, they keep a constant voltage (brightness in this case), make it float, and work under adverse temperatures.
