SonoranFun
Banned
- Joined
- Feb 18, 2004
- Messages
- 27
These are super easy questions and besic I'm sure but I don't know them so it's a big help.
a) Can I mount a 1W Luxeon using superglue?
b) Can I use a bolt as a heat sink?
I've though about this a few times and have a few lights with an aluminium cap that holds down the bulb. I was going to use my tap set to put threads in there and mount the 1W to the head of the bolt and just screw it in.
I figured I could drill a hole in the bolt for the + and midify the bottom to make contact with the batter contact. The bolt would ground to the body for the - contact.
Cheap and easy but does a bolt have enough mass to take care of a 1W led's cooling needs?
Thanks a million,
Adam
Thanks a million,
Adam
