I am hoping someone could help me out solving an issue I have with a Nitecore MH23. I recently purchased it and on it's first attempt to recharge the battery with the built in charger, everything seemed to go ok, but when I removed the charging cable, pressed and held the power button, it just flashed the turbo mode and then died. I unscrewed the cap and re-tightened and I got the code flash for a full battery (4 and 1, so not quite full) and if I half press for a moment it goes into low mode as it should. I can then cycle through the power levels (but not turbo) and if I turn it off, it will return to the selected level. If I try to cycle to turbo, I get the flash and ui lock until I loosen and tighten the cap.
Does anyone have any ideas on why this would be so and more importantly, how can I fix it?
I'm using a Nitecore NL189 3400mAh 18650 as the power source.
