This is the thread for the $5.00 ILL PILL KIT.
The ILL PILL is the simplest DC/DC Luxeon driver available. One IC, coil and Luxeon is all there is to the circuit.
This is the perfect kit for low cost experimenting with Luxeons, and other LEDs in 2AA flashlights. While the circuit isn't the brightest, or the most efficient, it is the simplest and lowest cost.
I have these to get started with:
So, I can drill and punch these out to make a few kits. The $5.00 kit would be just the two circuit cards, IC, toriod, o-ring, and wire required to assemble an Ill Pill. You would need to supply Luxeon and NX05 optic.
I will post the detailed assembly instructions here later (after I make them).
Stay tuned, DC/DC on the cheap coming......
Express your interest here, kits will be offered to those on this thread in order of response.
