The Fenix-Store
Results 1 to 8 of 8
Thread: lumintop Tool AAA
    Unenlightened
    Apr 2018
    Default lumintop Tool AAA
    I have a black one - about 2 years old. It only works on high. It will not cycle between low medium high. Any suggestions appreciated. I also emailed them.
    Thanks.
    Mark
    Apex, NC
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    Default Re: lumintop Tool AAA
    ... moved to LED Flashlights ...
    ... is the archimedes peak
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    What battery have you used for this ?
    Unenlightened
    Apr 2018
    Eneloop
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    Have you tested other cells, including a different (fully charged) eneloop, as well as a (fresh) primary ? ....
    Never used an over-voltage cell (which could have damaged the driver) ? ....
    Any unusual drops or damage ?
    Feb 2010
    Earth
    did you try installing the magnetic tail cap and trying it as a twisty?
    Flashaholic* Timothybil's Avatar
    Nov 2007
    The great state of Iowa
    Quote Originally Posted by Blackbeard View Post
    Since the tailcap has no active electronics, the magnetic tailcap isn't necessary. Just turn the light on with the tail cap, then twist the head back and forth to see if the modes work properly.
    Remember, Two is One, and One is None!.
    Unenlightened
    Mar 2018
    Might be a driver failure.
