I have just recently been dabbling in some battery pack building and got to try some lights on loan from friends on CPF. The main event in this post is the 6V Stinger Mod. This has been documented several times on CPF and goes back to some work that Dano presented a while ago. I have just completed building some custom 6V packs for the normally 3.6V Stinger series and had the opportunity to test the results so here they are:
Player #1: Stinger HP. A Stinger body with an HP "High Performance" turbo head replacement for the standard bezel. This is a 3.6V nominal light that uses a bipin bulb fed by 3 x sub-C 1800mAh nicads. This unit was graciously loaned to me by Milkyspit to help me iron out some battery pack tolerance issues.
Player #2: Stinger HP 6V. This is a Stinger whose pack has been replaced by a 6V pack. These are 5 x 1/2SC 1300 mAh nicads. The temporary lamp assembly is a reflectored unit for an SL-20X on loan from S4MadMan. It obviously doesn't fit in the Stinger head. I just tweaked the pins a little bit and stuck it in the pin receivers inside the Stinger.
Player #3: Mag18. This is the tried and true combo of a Mag4C body, WA01318 bulb and 4xSF123+1AA llithium. Very bright and correlated to about 350 torch lumens.
Player #4: Mag83. This is a Mag2C with a WA01183 bulb powered by 4 x 1/2SC such as are in the 6V Stinger pack. It is very potent for it's size and this 3.85A bulb gets 18 minutes of runtime from the tiny cells.
This first picture is simply a comparison of the three light bodies. You can see that the Stinger is the most compact of the three. The tube was designed to fit the sub-C cells so is noticeably thinner than the Mag bodies built for full-Cs.
Here is the StingerSL20X.
And here are the beamshotz. Exposure is locked and all torches are freshly charged. You can see that the Stinger HP is nothing to write home about, even with the HP head. I'm a bit jaded but it's just yellow and dim. With the 6V pack and a 6V LA though, it's a very nice little package. It'll probably still get 45-60 minutes of runtime with the Ultrastinger LA and will be much brighter and whiter than stock. It's still not as white as the WA bulbs but it's quite bright.
The Mag18 shows the characteristic bilobe hotspot of the large filament but the Mag83 displays a very nice rounded hotspot due to the miniscule filament of the WA01183 bulb.
All in all, I'd have to say a 6V Stinger is a very satisfying mod. Bright, reasonable run time and can charge in the cradle. Plus, with these very potent little 1/2SC cells, you're ready to drop in the WA01111 or the insane WA01160. Can you imagine having the brightness of the brightest current MagCharger mod in a torch smaller than a Mag 2C? Uh, I can. Of course there's the issue of meltage of the stock plastic lens but I think that can be handled.
Wilkey
This post was restored on 12/21/06
Wilkey
