Stainless
See it here:
http://www.shoplifestyle.com/store/product.asp?pf_id=5612&source=ntrcs
Looks like the only light to be able to stand in candle mode on both ends!
Two heads are better than one! One end of this compact light contains three Japanese Nichia LED bulbs, considered the world's best and brightest LEDs, and the other end features the even newer, Luxeon technology. The one-watt Luxeon light is 10X brighter than the brilliance of an LED!
Switching between the LED end and the Luxeon end can be compared to the difference between the low and high beams on your car. The energy saving LEDs will give you 5.4 lumens, which is more than you need most of the time. Should you want to turn on your "high beam", switch to the Luxeon, for up to 30 lumens!
Despite the enormous output the case remains cool to the touch. We also like the fact that this light uses inexpensive, easy to find "AAA" batteries (three—included) which will give you up to 35 hours of continuous light. The lightweight flashlight is water resistant and shockproof—virtually indestructible for a lifetime of use. Comes with nylon pouch. Measures 5¾"L x 1½"D.
# FL121 - Two Headed LED/Luxeon Flashlight - Now only: $49.95 Order now
I'm not a big fan of AAA batteries, and I assume that the switch requires cycling through the modes, but it might be just the ticket for someone.
