The NITECORE BR35 Bike Light uses an innovative dual distance beam, similar to car headlights, to simultaneously light distances both near and far to eliminate dark zones and ensure safety. Equipped with two powerful CREE XM-L2 U2 LEDs the BR35 produces a scorching 1800 lumen max output with 182 yards of throw to provide users with ample light for multiple environments. A simple three button user interface allows users to easily toggle light modes (short range beam, long range beam, dual range beam) using the mode (M) switch and adjust brightness levels using the plus (+) and minus (-) switches while on the go.
An easy to read OLED screen located on the top of the bike light displays the current light mode, brightness level, and the remaining runtime allowing riders to quickly check levels while in motion. A built-in 6800mAh Li-ion rechargeable battery provides users with up to seventeen hours of runtime, perfect for extended night time riding. When it's time to recharge the battery, users can easily recharge anywhere by connecting the supplied micro USB charging cable to any available USB power source, making this a great bike light for daily use or traveling.
$15 discount and free shipping coupon code from July 12 to July 23: NTBR35BL, purchase it on GearVita now:
https://gearvita.com/nitecore-br35-rechargeable-bike-light-dual-distance-beam-1800-lumens.html
Product Features:
● Rechargeable bicycle light with dual distance beam
● Utilizes 2 CREE XM-L2 U2 LEDs to emit a maximum output of 1800 lumens
● Uses a diffuse reflection board to illuminate the blind spot under foot with short range beam
● Onboard OLED display
● Built-in 6800mAh Li-ion battery
● Intelligent Li-ion battery charging circuit (via Micro-USB charging port)
● 3 modes available for different scenarios
● Remote switch provides convenient operation
● 4 brightness levels and 1 special function available
● A maximum beam intensity up to 7750cd and a maximum beam distance up to 176 meters
● High efficient constant circuit with runtime up to 17 hours
● Flood lighting system provides 100 degree lighting angle
● Advanced Temperature Regulation module
● Die cast unibody full metal housing
● In accordance with IPX7 waterproof
● 1.5m impact resistance
