Illuminated
I've been wanting a waterproof 4AA backpacking lantern modded with a 1W Luxeon Star and George's uFlex driver for a long time now, and the inexpensive Rayovac Kid's lantern seemed like a good sturdy host for such a mod, so here goes...
The heatsink was made by lopping-off the threaded part of an old MiniMag head and bezel and pressing it onto a solid piece of aluminum stock to provide a chunky, solid surface for the Star to sit on.. The MM bezel works perfectly for retaining the star without using screws.
To provide for routing the wires, first I drilled a 1/4" hole part-way through from the bottom, then drilled smaller holes on an angle from the perimeter, intersecting the larger one through the center. This provided for clean routing of wires through the center to the Star. A standard fiber washer purchased from my local Ace Hardware insulates the MM bezel ring from the Star's solder pads and provides firm, even pressure on the Star once the bezel is tightened. Four additional tapped holes were added to the bottom for mounting the heatsink inside the lantern.
The original bulb holder post was removed from it's base using the Dremel, and the tapped hole locations were transferred from the heatsink for the mounting screws.
The uFlex driver fit almost perfectly alongside the original mounting posts inside the base of the lantern. A couple of small pieces of double-sided foam tape held it to the posts while I added a few dabs of hot-melt glue here and there to secure it.
The momentary switch added to the side is the one supplied with the uFlex. I made a waterproof switch "sandwich" from the following bits:
- A rubber tailswitch dome cover from a cheap alum 2AA MM knockoff
- Two large rubber washers
- One O-ring
-A round piece trimmed from a Radio-Shack proto circuit board
-four #1 stainless flathead screws and nuts
The original switch ensures zero power drain when OFF for longer term storage, while the momentary switch on the side controls the uFlex. Because the last dimming level is stored in memory, using the lantern's standard ON/OFF switch also takes you back to the previous setting.
You can see George's runtime graphs HERE (Thanks George!) The runtimes are obviously greatly extended when using lower levels.
The lantern weighs 12-5/8 oz with alkalines, and it floats easily!
I used the lantern Saturday night around the campfire, and I especially like the ability to use only as much light as needed without disturbing dark-adapted eyes. I'm really happy with this mod, and can't wait to take it backpacking...
Thanks to Georges80 for such an outstanding product as the uFlex Driver /ubbthreads/images/graemlins/smile.gif
John
- One O-ring
John
