Re: Diamond-flashlight 3W Luxeon PR Bulb? *UPDATE*
utomatoe,
I'm driving a Q2H HD Star in a 4AA Rayovac Kid's lantern with a uFlex at 380 ma. The uFlex obviously costs more than the LM317 and resistor, but you can't beat the efficiency and features of the uFlex.
It runs happily for 5hrs & 20 minutes runtime on high with 4AA alkalines, 12 hours on 4AA lithiums according to George's run time graphs. It'll run for much, much longer when using the lower settings. The uFlex is absolutely superb! AND - the thing can really suck all the useful power from your batts to boot. After just starting to fall out of regulation on highest setting, I put two of those batts into my Opalec and they lit up the red low-batt led. Since the uFlex can still say in regulation at the lower level settings, I imagine it could drain the batts virtually completely.
The uFlex driver is user-configurable for 380 ma or 760 ma, so you might even be able to drive a Lux III from 4D alkalines (and a decent heat sink) in your larger lantern.
The LM317 is inexpensive and easy to use, but I agree with RussH - you need a good 3 Volts above the LED Vf to stay in regulation, and it is not nearly as efficient as a down-switching current regulator like the uFlex from georges80, or a DB400 from dat2zip's sandwich shoppe.
[EDIT - there's always the inexpensive option of using a simple current-limiting resistor for your 4D lantern. You could even use a separate switch to bypass the resistor once you notice the LED starts dimming.]
Have fun!
John
