zieloczek100
- Joined
- Nov 13, 2016
- Messages
- 68
[FONT="] [/FONT]
Hello,
My name is Eryk. I am writing reviews in Polish.
Reviews I translate – google translator.
[FONT="]Flashlights from Lumintop are always small works of art, and it is no different in this case.[/FONT][FONT="] [/FONT][FONT="]Classic design, with a button placed under the thumb, matt anodization and a beautiful design, which the producer is famous for.[/FONT][FONT="] [/FONT]
[FONT="]On the font's note, we only find the manufacturer's stamp and information about what is inside.[/FONT][FONT="] [/FONT][FONT="]The back of the package basically covers all the most important technical information[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]In the middle except the lamp itself we can also find:[/FONT][FONT="] [/FONT]
[FONT="]- a brilliant leash on the wrist (I love it),[/FONT][FONT="] [/FONT]
[FONT="]- holster[/FONT][FONT="] [/FONT]
[FONT="]- spare o-rings,[/FONT][FONT="] [/FONT]
[FONT="]- paperology[/FONT][FONT="] [/FONT]
[FONT="]The whole is enclosed in an ecological packaging[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Matt, black anodisation, black button and metal ring around the button and reflector - hmmm, beautiful;[/FONT][FONT="] [/FONT][FONT="])[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]From the top, classically, a metal ring, under it a red oring, fast with coatings, OP reflector and diode XHP70.2 (unfortunately it is not perfectly centered)[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Under the ring of the relfector we will find a large logo and the name of the manufacturer.[/FONT][FONT="] [/FONT][FONT="]In my opinion, the logo itself is doing a great job;[/FONT][FONT="] [/FONT][FONT="])[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Below is a massive ribbing, whose task is to dissipate a lot of heat, and in the highest mode the flashlight can warm up really fast[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Rubber button (probably silicone), very pleasant to touch, each press ends with a characteristic and audible click, there is no question of any inaccuracy[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]The middle tube is permanently mounted[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Flat cap, allows you to place the flashlight steady in a standing position.[/FONT][FONT="] [/FONT][FONT="]In this place there is an element for assembling the leash[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]The biggest disadvantage and also the big advantage of this flashlight is the cap.[/FONT][FONT="] [/FONT][FONT="]On the one hand, well-made, flat, on the other hand, there was no sprays in it ... which unfortunately does not allow using 26650 or 18650 cells (emergency), without protection.[/FONT][FONT="] [/FONT][FONT="]Unwired 26650 cells are simply too short to function normally in this flashlight.[/FONT][FONT="] [/FONT]
[FONT="]The solution is: place a coin under -, braze the brass discs to the plus, use cells with protection or bail the spring in the cap.[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Threads well made, but completely dry at the factory[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]The most important part of the flashlight (and not only), or the controller[/FONT][FONT="] [/FONT]
[FONT="]The control is very simple and intuitive:[/FONT][FONT="] [/FONT]
[FONT="]- one click turns on the flashlight[/FONT][FONT="] [/FONT]
[FONT="]- single clicks change modes in the loop - from low to high (ie 150-1800lm)[/FONT][FONT="] [/FONT]
[FONT="]- We activate TURBO with a double fast click[/FONT][FONT="] [/FONT]
[FONT="]- Eco mode (8lm) is activated by holding the button on the switched off flashlight until it is switched on[/FONT][FONT="] [/FONT]
[FONT="]Of the most important functions, that's basically just that.[/FONT][FONT="] [/FONT]
[FONT="]Stroboscopic mode is hidden, you must activate it in Eco mode and press the button twice (do it quickly).[/FONT][FONT="] [/FONT]
[FONT="]Protection against too low charge of the cell - the button will start flashing in red reminding you to charge or replace the cell.[/FONT][FONT="] [/FONT]
[FONT="]Protection against accidental switching on - hold the button for 3-4 seconds until it starts to flash.[/FONT][FONT="] [/FONT][FONT="]From now on pressing the button the flashlight will turn on as long as you keep the button.[/FONT][FONT="] [/FONT][FONT="]In order to deactivate the lock, we must loosen the cap for a moment (there is no other way to disable the lock)[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]The manufacturer promises 1800lm in High and 3500lm in TURBO (for 3 min).[/FONT][FONT="] [/FONT][FONT="]ODF30 has a temperature sensor, testing the flashlight without cooling, after 3 minutes broke the brightness to about 1800lm, and a moment later reduced it even more so that it does not exceed 55 ° C.[/FONT][FONT="] [/FONT][FONT="]While maintaining adequate cooling, the graph looks better than good [/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]And a small photo session among Nitecore EC4, Rofis MR70[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Field shots, camera settings ISO-200, f / 2, 1s, white balance - Fluorescent H[/FONT][FONT="] [/FONT]
[FONT="]Lumintop ODF30 - low mode[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Lumintop ODF30 - medium mode[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Lumintop ODF30 - high mode[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Lumintop ODF30 - TURBO mode[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Rofis MR70 - TURBO mode[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Fenix UC52 - TURBO mode[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]A few words of summary:[/FONT][FONT="] [/FONT]
[FONT="]Lumintop once again showed that their flashlights, apart from a great performance, offer something more, I mean a beautiful, classic look with a touch of modernity.[/FONT][FONT="] [/FONT][FONT="]Under this small casing, he hides electronics with a very intuitive control that will stabilize for almost 1800lm without any major problems.[/FONT][FONT="] [/FONT]
[FONT="]No USB port - better protection of the flashlight against water at the expense of something ...[/FONT][FONT="] [/FONT]
[FONT="]The biggest drawback is undoubtedly the lack of a spring in the cap, and if this is a problem that each of us can solve, then such a move by Lumintop is at least strange.[/FONT][FONT="] [/FONT]
[FONT="]In the price of around 50USD, I think that this is another interesting proposition of a small flashlight with an XHP70 diode supplied from 26650 cells, free of major drawbacks, mainly utility ones.[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]Hello,[/FONT][FONT="] [/FONT]
[FONT="]He delivered the flashlight for tests -[/FONT][FONT="] [/FONT][FONT="]https://www.banggood.com/Lumintop-ODF30 ... endongling[/FONT][FONT="] [/FONT]
[FONT="]With the code - CFNKL, the price is lower by 25%.[/FONT][FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
Hello,
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
