Imalent
Results 1 to 17 of 17
Thread: FOUND ... needed delivery of 18650 batteries, FAST !!
    Unenlightened
    Sep 2018
    Default FOUND ... needed delivery of 18650 batteries, FAST !!
    So, last February my husband and I did a night dive in Curacao which was totally awesome but we both had our flashlights die which was not so awesome. Luckily we had a backup so we were able to make it back to shore.
    I have researched the heck out of dive lights and just bought four new ones - two primaries and two back ups.
    They all came without batteries which I thought would be no big deal until I started to try to figure out what the heck to buy. I didn't realize that you couldn't just go into your local Home Depot and pick some up. We fly out on Thursday so I am getting desperate. I have tried to research but I keep getting more and more confused.
    I know that I need six 18650 lithium-ion button top batteries with a minimum of 2600 mAh (up to 3400 mAh)and 3.6 or 3.7V. They need to have a high capacity rating versus a high discharge rate. I realize they are not going to be cheap but budget is a concern.
    Can someone please suggest which exact battery to buy and where to buy it from so they will be here by Wednesday?
    I also need to know which battery charger to get. Preferably one that can charge up to four batteries at a time.
    Any help will be greatly appreciated!
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    Default Re: Please help! Running out of time!
    Hello and welcome to CPF
    Please help CPF help you by editing your title to something a bit more specific ...
    ... is the archimedes peak
    Desperate times indeed.
    For batteries, Samsung, Sony, or Efest.
    For charger, Iím liking the Gyrfalcon All 44.
    for retailer, Mountain Electronics in Utah is excellent. You may be able to call them and ask them to rush the order. Pay for 2 day shipping to be sure you have the items early enough. I would definitely order today!
    Sorry I can't help with the Battery / Charger side - I'm pretty much a Novice like yourself.
    However as far as your time issue - it might be possible to have whomever you purchase from ship straight to your destination instead. Once you pick a source that's something you can talk to them about.
    Good luck & have a fun, safe trip.
    If budget is a problem get an Xtar vc4 charger and whichever 3000mah+ batteries you want from mtnelectronics. Call or email Richard and tell him you need them in a rush. Heís fantastic to work with.
    hunter, fisherman, flashlight enthusiast
    skillet's Avatar
    Jan 2005
    Green Co. , Bluegrass State
    Any local vaping shops (e-cigs and the like) will have batteries and chargers in stock, or at least the ones around here do. They have had quality cells of varying capacities and decent NiteCore chargers. I would think the one in your location would just as accommodating and able to assist you and answer your questions about the cells and chargers.
    I DO NOT HAVE...
    AURORAPHOBIA, OR EOSOPHOBIA, OR EREUTHOBPHOBIA, OR ERYTHROPHOBIA, OR ERYTOPHOBIA, OR PHENGOPHOBIA, OR PHOTOAUGLIAPHOBIA, PHOTOPHOBIA, OR SELAPHOBIA..
    Flashaholic* mattheww50's Avatar
    Jun 2003
    SW Pennsylvania
    Shipping straight to the destination tends to be very difficult. Li-Ion cells are classed as hazardous cargo, so you need to be licensed for Hazardous cargo to carry it. Then there are require disclosures on the shipment. Unless the shipper has experience in dealing with the shipments, the paperwork can be a real challenge. As far as I know FedEx is licensed to carry hazardous cargo, but you are likely to pay dearly for that capability. Shipment via USPS even via express mail is legally impossible. The only way you can Li-Ions is if they are actually installed in the equipment, and even then you are limited to 3 cells, and the presence of the LiIon battery must be disclosed on the labeling.
    Honorary Aussie
    Feb 2014
    USA
    I second the Mountain Electronics rec. Iíve had good experiences with them on several orders.
    Best of luck with your purchase.
    It is better to buy a beautiful, expensive, custom flashlight than to curse the darkness.
    Flashaholic* DIWdiver's Avatar
    Jan 2010
    Connecticut, USA
    As I recall, lithium batteries need to be shipped ground. I'd go the vape shop route.
    The best website for 18650 on the planet!!
    https://www.orbtronic.com/
    Jan 2010
    Connecticut, USA
    Quote Originally Posted by Nichia! View Post
    NOT if you are looking for a bargain.
    Unenlightened
    Sep 2018
    Thank you everyone for all the suggestions!
    So I ended up spending $60 to buy 4 '3400mAh 18650 Battery ORBTRONIC Protected Button Top Rechargeable High Performance Li-ion 3.7V for High Power Flashlights' from Amazon. They will be here by Monday and the total was cheaper than trying to get rushed ground delivery from any of the other shops. I am not sure why Amazon can send them by air when the other shops all needed to send ground. It's been an expensive introduction to the world of lithium-ion batteries but I would rather spend extra $$$ than have no light on a night dive. :)
    Just an FYI for anyone else who needs to buy flashlight batteries: DO NOT BUY BATTERIES MEANT FOR A VAPE!!!
    This is where I ended up getting very confused and why I posted on CandlePowerForums for a recommendation of an exact battery to buy not just a '18650 lithium-ion button top battery with a minimum of 2600 mAh'.
    Please correct if I got this wrong but from what I have read, for a vape you want a 'high discharge rate' (i.e. can deliver a lot of power all at once). With a high discharge rate, you go through a lot of power in a short duration of time. For a flashlight you want a a lower max discharge rate so that it will deliver at a lower discharge rate for a long period of time. This is why the listing for the battery I purchased clearly states 'NOT FOR E-CIG MODS- FOR High Power FLASHLIGHTS ONLY'.
    Again, thanks for the help!
    Moderator
    archimedes's Avatar
    Mar 2011
    CONUS, top left
    Default Re: FOUND ... needed delivery of 18650 batteries, FAST !!
    Quote Originally Posted by Sneeg View Post
    .... I know that I need six 18650 lithium-ion button top batteries with a minimum of 2600 mAh (up to 3400 mAh)and 3.6 or 3.7V. They need to have a high capacity rating versus a high discharge rate. I realize they are not going to be cheap but budget is a concern.
    Can someone please suggest which exact battery to buy and where to buy it from so they will be here by Wednesday? ....
    Glad to hear you found what you needed
    Also, I don't recall any mention of the exact flashlight make and model for which these are intended.
    Please be aware that there are some with very high current draw indeed ....
    Jun 2003
    SW Pennsylvania
    Amazon has their own fleet of leased aircraft operated exclusively for them, and as a result they are are not classed as 'common carrier', so many of the regulations that common carriers such as FedEx, UPS or DHL have to obey, Amazon may ignore.
    You sort of have that backwards in that E-Cig mods sometimes demand a LOT more current than flashlights and often some of these mods you need high current batteries while many flashlights (and some other devices) can use low and higher current batteries with no issues. Unless a light has higher current demands than a battery can deliver it is possible a higher current battery could give you LONGER runtimes (at the same capacity) than a lower current battery due to possible lower internal resistance contributing to less power loss as current ramps up in the higher modes.
    In other words you can use EITHER high or low current batteries as long as the output of the lower current batteries is enough to handle the device/flashlight etc.
    Jan 2010
    Connecticut, USA
    High discharge rate cells are needed for vaping because you need intense heat almost instantly. This does not preclude that same cell from being used at lower discharge rate, and a vape cell would work perfectly fine in a flashlight.
    The reason you may not want to use a vape cell is that high rate cells will tend to have lower capacities, if both are generally the same quality. A 2600 mAH 20C rated cell will work just as well as a 2600 mAH 5C rated cell if run with a 1C load, perhaps even a hair better. You can get a 3500 mAh cell for your flashlight, but I don't think you can for your e-cig.
    Oct 2013
    USA
    Also be aware that (rewrapped) cells marketed for vaping often specify the max current for pulse (vs. continuous) loads, without explicitly saying so. Further they may exploit the fact that there are no standards for such pulse ratings in order to exaggerate the rating to gain a competitive edge. These matters are discussed more in-depth on vaping sites, e.g. see Mooch's reviews.
