What DOES the ready for service option do for you?
Status
Not open for further replies.
Bushman
I see it but what would happen if I toggled it off? What function does it serve?
mut
OK
I think it lets you know when you insert the battery correctly or not, and if you insert a weak battery it will let you know. I think that's about it for what it does. I think that in some other posts it was causing some funny effects when left in the cold also.
Hope this helps.
/ubbthreads/images/graemlins/grinser2.gif
Sean
IL, near St. Louis MO
Re: What DOES the ready for service option do for
Funny effects from freezing? Did you ask Mr. Science about this? He's the expert on freezing Arc's. /ubbthreads/images/graemlins/smile.gif
Anyway, I turned ready for service off, as I couldn't determine a good reason for it. Plus it was annoying to watch everytime I twisted the battery tube down (from being "locked out") before use.
chamenos
Singapore
nothing...so i turned it off /ubbthreads/images/graemlins/smile.gif if your light boots up with the LED faintly glowing, then the battery went in the right way. once its done booting up, turn it on and put it to boost mode. if it goes to level 1 without stepping down, your battery is fine. you can do all of that faster than the RFS sequence takes to finish /ubbthreads/images/graemlins/smile.gif
Status
