Fenix Outfitters
Results 1 to 14 of 14
Thread: Olight S1R II Ti/Cu - They really knocked it out of the ballpark with this quintet!
    Default Olight S1R II Ti/Cu - They really knocked it out of the ballpark with this quintet!
    I love small, powerful, hi-tech, beautifully designed and made flashlights (like so many of us). Here's what I love about these 5:
    1. Knurling is high and very well done. Beautiful.
    2. Magnetic base charger is awesome and quick.
    3. Beautiful beam, with a very good throw as well as brightness. Normally I like cool white beams, say 6500K. But with these, I even like the 3000K warm beam of Winter.
    4. Very small, vest pocketable, lights with very bright and throwy beams.
    5. Blue bezel is lovely. The finish and color of all 5 are 1st rate.
    6. UI is one of my very favorites. Double click to go right to 1K LU. Long hold to go to moonlight. Smooth ramp down on turning off (really cool!). Quick on and off.
    7. Charge-level light in button. Quick to charge.
    8. Easy to use mode button. So easy to press and click.
    9. The Cu version is especially gorgeous, as they tend to be. It's UNC (uncirculated, to coin collectors) in its delivered, sealed, deoxygenizing package. I haven't been able to bring myself to open its packaging yet. I'll save it like a fine vintage wine, for that special occasion.... But soon....
    10. These far surpassed my expectations. I love all 5 versions, even Winter.
    11. Getting the full set at 30% of was really nice too.
    I've asked Olight if the clips can be safely removed, without damaging the light's surface underneath them. The clips seem to have enough play to be removed by pulling. The clips are actually nice, and make it easy to find the mode button just by feel, but I don't think I really need them, although I'm undecided as yet.
    Nov 2014
    Marin County, CA. Out in the woods
    Default Re: Olight S1R II Ti/Cu - They really knocked it out of the ballpark with this quinte
    I got the Spring, and Autumn. They are great. Closest I'll get to owning jewelry. They make perfect ball cap headlamps.
    fyrstormer's Avatar
    Jul 2009
    Maryland, Near DC, USA
    I prefer the S1, even though it isn't available with as many cool finishes, specifically because of the clip design. I don't particularly like clips on lights this small, so I remove them, but the S1R II's design leaves an obvious empty spot when the clip is removed. The old design didn't have that, and was therefore superior in my opinion.
    Olight set the bar high years ago when they released the S1 baton in copper. Its great too see them years later still do copper and other limited editions of their smaller lights, same as with the i3t copper, great light. Thats why other makers copy their light design and not the other way around. I wish more would make lights in different materials and tints, the regular black lights are boring too see. Time for some new innovation next year i hope.
    fyrstormer's Avatar
    Jul 2009
    The reason for all the black-dyed anodized-aluminum lights is black dye hides anodizing inconsistencies very effectively. It's cheap and easy to produce in high quality, just like the Ford Model T.
    I agree it's not my favorite finish, though. I much prefer raw finishes, but that requires a base metal with sufficient hardness that it doesn't need a coating, like steel or titanium. Naturally those cost a lot more.
    I値l be honest I知 kinda bummed that the titanium (Winter) is less bright does titanium disperse heat less efficiently than brass or copper? I知 not really a fan of the copper or brass look so I may end up going with an aluminum unit
    Flashaholic* Crazyeddiethefirst's Avatar
    Mar 2012
    Southern California
    ipaulr,
    To remove the clips without marring the finish, I use a plastic straw & push it over each side of the clip as far as it can go. When the clip is then removed the plastic prevents the tension arms from scratching the surface. Over the years it has been very effective. Just reverse the process to put the clip back in place without damage.
    Mar 2012
    Southern California
    Default Olight S1R II Ti/Cu - They really knocked it out of the ballpark with this qu...
    bartonjd, did you get the warm or neutral LED with your titanium light? Both have noticeably less Lumens than the cool white LED, but a much better color rendition. Often I will buy two titanium lights, one neutral & one cool. Titanium does not dissipate heat near as well as copper, but in my smaller lights(16340 as compared to an 18650 cell), I cannot distinguish a difference in Lumens if both have same Led.
    I actually have not purchased one yet I致e been trying to decide which one to yet, I love the look of the winter and the 10th sounds fun but I致e been unsure because the brightness is lower than the others and except for The 1.5 M of turbo.
    fyrstormer's Avatar
    Jul 2009
    Quote Originally Posted by bartonjd View Post
    Titanium conducts heat surprisingly poorly for a metal, but it's not bad enough to risk damaging any flashlight with a sane level of output.
    However, all of the "Seasons" S1R IIs are made of titanium; the only difference is the coating. The reason the "Winter" version is less-bright is because it has a warm emitter. White LEDs are just blue LEDs with phosphor coatings, so warm LEDs require thicker phosphor coatings to ensure more of the original blue light is downconverted to warmer colors.
    Flashaholic* MikeSalt's Avatar
    Jan 2007
    Stoke On Trent, Staffordshire, UK
    Definitely knocked it out of the park in my opinion, based on my experience of the 'Winter' edition
    Deleted
    The Winter edition is nice, but the warm is VERY orange, just FYI. The clip is also somewhat of a pain to keep bent away while unscrewing the battery compartment. Not that big a deal since the light has onboard charging, but something of a design oversight.
    Quote Originally Posted by somnambulated View Post
    Despite how warm the light is are you happy with it? Would you prefer one of the other editions? Do you have any beam shots?
