Malkoff
Results 1 to 2 of 2
Thread: Lexels driver compilation
    Flashaholic Lexel's Avatar
    Sep 2016
    Germany
    Default Lexels driver compilation
    DD+7135 drivers:
    12/15mm
    new for 2 S eliminating AMC7135 dedicated indicator resistor and pad
    2 channel (Narsil with indicator)
    3 channel (mainly Bistro HD)
    Oslon Black
    17-19mm
    20mm
    new 1S/2S combination from my LX driver
    C8F 21700
    Oslon Black flat with P-FET
    20,5mm Astrolux S42
    21mm (discontinued)
    Skilhunt H03
    20-22mm
    (discontinued)
    new version with 1S 3 channel AMC and 2S dual MOSFET
    24-30mm
    v3.1 with a little bugfix (1S only now, 2S new one)
    new 2S version
    without AMC for 2S, also added two switchLED support
    Programming port (under development curently have v2.0 and 3.0 available)
    28-33.5mm
    small current FET 1-4S
    38,5mm Cuoroi D01
    42mm
    TN42 2S/2P DD (discontinued AMC problem at 2S)
    46mm
    2S/2P MT03
    new enhanced version no more AMC7135
    3 step filtering to get the rininging from PWM under control
    47,5mm
    Astrolux MF01 (discontinues AMC problem at 2S)
    BLF Q8
    Buck drivers:
    Input 6 to 25V
    Output 6-20V 1-8A as requested
    The input and output voltage difference defines the switching frequency so they get set for your light individually
    I have calculations for various inputs/outputs
    20mm
    for Convoy L2 or similar
    22mm
    new more efficient MOSFET and minor changes
    23mm
    for Klarus XT11/12GT running 2 18350s for Oslon 1mm & 2mm² or other 3V LED including Black flat
    30mm
    new for Convoy L6 more efficient MOSFET
    30-33.5mm
    Lumintop SD75 8A 2-4S buck
    42mm
    TN42 XHP35
    new version up to 8A also for TN40S mods with XHP35s
    Niwalker BK-FA30 v2
    47,5mm
    MF02 XHP35
    new version MF02/04S 12V up to 8A
    46 mm MT07 / MT07S / MT09R(XHP35)
    Dual Buck 46/47,5mm 4S/1P or 2S/2P
    MF01 v2 3S 13A dual Buck driver with new MOSFET and now single sided
    should fit MT03 as well trimmed to 46mm
    Acebeam K65 latest gen with programming port(under development waiting on boards)
    BLF GigaThrower driver
    XHP70.2 or Oslon Black Flat up to 8A
    as the marketplace needs to pay I can not start any sale here on CPF
    Flashaholic* id30209's Avatar
    Mar 2008
    Europe
    Default Re: Lexels driver compilation
    Where can i get some more info about “how to”? I’m very interested in 14mm and 17mm versions
