HDS Systems
Results 1 to 7 of 7
Thread: Lost my Olight S1 Baton... how are you liking the S1R II
    Jul 2009
    Chandler, AZ
    Default Lost my Olight S1 Baton... how are you liking the S1R II
    Lost it early December about 2 hours from home, in the forest, cutting down our Christmas tree while it was snowing. I either lost it while cutting the tree down in an awkward position. Putting the tree on top of our SUV, or while putting on or taking off the chains to get out up a hill from where we 4x4'd into get the tree.
    I got it right after they came out and it was my daily carry and work(IT) flashlight. I ran lifepo4 RCR's in it. It is/was an awesome light.
    So...how is everyone liking the S1R II as its replacement so far?
    Enlightened Wonder's Avatar
    Apr 2009
    upper midwest
    Default Re: Lost my Olight S1 Baton... how are you liking the S1R II
    I never owned a S1. I have S1R's and S1R II's and like them a lot. The S1R Gen I AKA Turbo S should be the same feel and operation as a S1 with the addition of magnetic charging and more output. The Gen II is a all new light, mostly looks IMO. I'm old school and like the looks of the Gen I lights better, you may not agree. Either will work as a replacement for the lost S1. Keep in mind the magnetic tail cap can be a good or bad thing dependent on use. I do not throw my keys and light in the same pocket so no problem for me. On paper
    S1R Baton Turbo S
    LEVEL 1 (lumens) 900/300 1.5m/50m
    LEVEL 2 (lumens) 600/300 1.5m/55m
    LEVEL 3 (lumens) 300 1h
    LEVEL 4 (lumens) 60 4.5h
    LEVEL 5 (lumens) 12 33h
    LEVEL 6 (lumens) .5 15d
    Strobe, timer
    Beam Distance (ft) 476 (m) 145 (cd) 5250
    Waterproof IPX8, Cree XM-L2 LED with TIR optic lens
    Customized Olight HDC RCR123A 550mAh Battery PN ORB-163C05
    Other compatible batteries CR123A/standard RCR123A no charging no turbo
    S1R Baton II
    LEVEL 1 (lumens) 1000/300 1.5m/37m
    LEVEL 2 (lumens) 600/300 1.5m/45m
    LEVEL 3 (lumens) 60 3h40m
    LEVEL 4 (lumens) 12 20h
    LEVEL 5 (lumens) .5 8d
    Strobe, timer
    Waterproof IPX8, Cree XM-L2 CW LED with Gen 2 TIR optic lens
    Customized Olight IMR RCR123A 550mAh Battery PN ORB-16C05-10C
    I have the S1R ii in titanium, and it's a great little light. Small enough to comfortably EDC, but but that 1000lm is super bright when you need it.
    Flashaholic* Crazyeddiethefirst's Avatar
    Mar 2012
    Southern California
    I have several of all generations and believe the S1r II is an excellent replacement. It has the turbo power if you want it but since I use the lower settings I find the runtimes excellent.
    I've been using it daily for about a month and a half and it's been pretty great. The beam profile is good for a general purpose with a mix of throw and spill. The timer feature, on-board charging, and tail magnet are all surprising useful.
    My only real gripes are that the 6500K and 70 CRI is harsh. A warmer emitter with better color rendering would be a significant improvement. High and turbo levels are too close together. It would be more useful if high were set nearer the light's sustainable output level 150~300 lumen.
    If I lost my S1R Baton II, it would be hard to decide between buying another one and Zebralight's new SC64c LE, which is just a little bigger:
    Model SC64c LE 4000K LH351D S1R Baton II
    Manufacturer Zebralight OLight
    Tint 4000k 6500k
    CRI 90 70
    Price (light) $79.00 $64.99
    Price (battery) $6.00 $0.00
    Total $85.00 $64.99
    Battery 18650 IMR16340/123
    Samsung 30Q OLight
    3000 mAh 550 mAh
    Runtime @ 300 lm > 3 hours < 45 minutes
    Weight w/o battery 1.3 oz (38 grams)
    Weight w/battery 3.0 oz (86 grams) 1.8 oz (51 grams)
    Head diameter 0.96 inch (24.5 mm) 0.82 inch (21 mm
    Body diameter 0.82 inch (21 mm
    Length 3.64 inch (92.5 mm) 2.48 inch (63 mm)
    High 828/314 @ ~2 min/3+ hr. 1,000/300 @ 1 min/45 min
    Medium 83 lumen @ >12 hours 60 lumen @ 3.6 hour
    Low 15.3 lumen @ ~2.8 days 12 lumen @ 20 hour
    Moon 0.6 lumen @ ~1.5 month 0.5 lumen @ 8 days
    Waterproof IPX8 IPX8
    Warranty 1 year 5 year
    *The runtimes assume that Zebralight's drive outputs levels are unchanged for this new offering.
    Mar 2003
    Austin TX
    Au Re: Lost my Olight S1 Baton... how are you liking the S1R II
    Quote Originally Posted by freeride21a View Post
    I have a pair of S1R turbo and a pair of S1R II and I now carry the S1R II constantly. The II is slightly smaller and the interface is more friendly, in my opinion. There is also a charge indicator on the later, though i must admit to rarely needing it as i alternate lights everyday. I can't say enough good things about these lights, but if you liked the turbo you will love the S1R II Baton.
    P.S. i have an S1mini in bead blasted titanium that is the ultimate finish as far as I'm concerned. It was a high cri light and i loved it, though i think the new titaniums are too warm for my liking.
    SRB - CPF member #3793
    Aug 2008
    Clinton Louisiana
    It's been my EDC for 2 months now, it's an awesome little pocket rocket, get one!
