latearrival
- Joined
- Jan 18, 2019
- Messages
- 2
Hey guys. I'm completely new to your world, having just bought my first 'quality' flashlight - a Fenix UC30. I'm having a problem charging it and I thought the community might have some suggestions for me - user error perhaps? I've searched the forum and Google but couldn't find anything apart from it maybe being a physical fault or fully depleted batteries needing longer to charge...
My problem is that the red charging light is displayed when I have the charging cable plugged in, but the battery does not charge. After 4 hours, the battery is still completely dead.
More info:
Any ideas on what could be wrong? I don't want to have to go back to Maglites
(I don't have a multimeter)
More info:
- My Fenix UC30 is a 2017 model, this one.
- It has the original Fenix 2600mAH rechargeable battery in.
- The torch is a month old and has never been used apart from turning it off and on again a few times. It worked fine.
- The torch fully discharged itself in the drawer by the button getting accidentally depressed. This is the first time I've tried to recharge it.
- When I plug the provided micro-USB charging cable in and press the power button (as per the instructions), the red light displays continuously to indicate that charging is taking place.
- If I power on the torch while the charging cable is plugged in (and connected to a power source), I can turn the torch on.
- If I power on the torch while the charging cable is plugged in (and connected to a power source), I can turn the torch on even with the battery removed.
- When the charging cable is plugged in (and connected to a power source), I can remove the battery and the red charging light stays on.
