Looks like a angle head version of the 1L-1AA:
https://www.streamlight.com/en/products/detail/index/protac-90
If you can use a Primary then you can use a NiMH too they are just recharging Primaries,Same basic voltage no problemo.Looks interesting.
Too bad NiMh aren't listed a a battery option.
I'd also prefer a third, lower mode about 5 lumens.
They still suggest NiCad in many of the lights?If this is anything like the 1L-1AA, it will run fine on Eneloops! I think that Streamlight does not test or recommend eneloops, but the work fine. They probably test/recommend the Energizer ultimate lthiums because they are use by the Military.
Yes I am saying that compared to NiMH ,NiCad are for Cavemen.Don't know. NiCds should work being similar to NiMH. My 1L-1AA will run on all sorts of stuff, including cheapo heavy duty AAA's.
I brought it up,did you read the thread?For the record, no where on Streamlight's webpage for the light does it say anything about NiCad cells. I'm not even sure how that came up here.
Where do you buy this flashlight? I see the polytac advertised but not the protac aluminum light.
BriteGuy says "coming soon".
Typically Streamlight releases new stuff in late March or early April.
Brightguy is showing the Protac 90 in stock now.
It's been available for a couple of weeks. I ordered mine on the 14th and it came in a few days later. Works like the Protac 1l-1aa as far as batteries but has slightly lower lumens for slightly longer runs times. A bit more "floody" as well. Nice little light.
