Jesse_hoang
- Joined
- Aug 13, 2017
- Messages
- 12
Hi everyone, my first post here!
I've been doing some flashlight reviews on my website but in Vietnamese only. I think it's a good chance to improve my English as well as to share my experience with you :wave:
So Olight dropped the Warrior X a month ago with a claim that it would change the way we use tactical flashlight, let see if they're just talkers!
This light is very similar to the Olight M23 by looking but it feels much more solid holding on hand. Olight used more material on this for the dual-layer body and larger heat sink plates.
Magnetic tail cap was remained the same as on the M2R
Deep smooth reflector combines with Cree XHP35 HI emitter that promise a 560 meters beamshot, which is impressive for its size.
One more new feature on this light it that the simple UI of only 2 brightness modes: 2000 and 300 Lumens. It also has another mode group that containing additional strobe mode.
Specificaitions
Unboxing
It's known that Olight has changed their packing cases recently: nice white carton box with smaller size and better organized. The warrior X comes with an Olight 3000mAh 18650 high drain battery (i believe it's a rewrapped samsung 30Q), a nice holster, magnetic charging cable and a tactical grip ring. No spare o-rings ỏ lanyard included.
Brightness parameters
This tactical grip ring is for replacing the anti-roll ring. You have to remove the clip as well in order to install it.
Olight also introduced 2 new items: the Magnetic Remote Switch and a gun mount. I'll talk about them in details later.
Impressions
It's BEAUTIFUL!! i'm not even overrating, its design is so clean and modern as well. The build quality and finishing is very nice as they always do on their other lights.
You will immediately notice these larger heat sink plate on its head. They should guarantee good heat dissipation performance when the light running on high.
This light is handy as well, not to big to carry around everyday. However, i find it a little uncomfortable carrying this light on my pocket due to the large head. I'm not a big fan of belt carrying as well so letting it stay on my backpack seems okay.
Using the light in this position seems challenging because of the hollow tail cap switch.
Compare to other Olight tactical lights. From led to right: Olight 18650 battery, Warrior X, M23 Javelot, M2R Warrior, M2T.
The Warrior X has then same size as the M23 Javelot and a a little bit heavier.
It weights 217g with the battery
The M23 is 20g lighter
Compare to the Olight M2R/M2T. These 2 are better idea for pocket carry
and for those who prefer flood beam
Only the tail cap can be unscrewed, the head is glued.
Nice and clean threat. It's also anodized
a better view of the dual layer body, looks solid as hell
the anti roll ring also plays a role in improving holding experiment
nice pocket clip, not to hard imo
The body grip is the same as on the M2R/M2T
the blue benzel is one of the iconic on a lot of Olight's flashlight
It protects the lens from scratching and for self-defending, breaking glass,...
the domeless XHP35 HI, perfectly centralized. I tend to judge a light negatively as soon as i see the LED is not in the right place as it should be.
Magnetic tailcap Switch
As i said, the Warrior X inherits the tailcap design from the M2R. First time users might find it difficult to cooperate with this switch but they would get used to using it soon.
It's can tail stand well.
this light charges via a magnetic cable which utilizes 5V/1A USB source
i measured the charging current by 5.14V/0.86A. It normally takes roughly 4 hours to fully charge to battery.
an indicator light is equipped, which will show red while charging and turn green when full
UI
The Warrior X has a very nice, simple and smart UI. 3 modes in total are divided into 2 Group:
- Group 1: High (2000 Lumens) and Low (300 Lumens)
- Group 2: High (2000 Lumens) and Strobe (2000 Lumens)
Group 1 is default when out of the box. Switching between 2 group is simple.
First Step: loose the tailcap
Next Step: tighten the tail cap while pressing the switch
While in group 1:
Softly-press the switch for 0.5s to turn the light on fixed low 300 Lumens. Press again to turn off
or softly-press and hold the switch for >1.2s to temporarily turn the light on 300 lumens, release to turn off
Fully press for 0.5s to turn it on fixed high 2000 lumens, press agian to turn off
or fully press and hold for > 1.2s to to temporarily turn the light on 2000 lumens, release to turn off
While in group 2:
Soft-press will turn the light on temporary High, hard-press will set to to temporary strobe, release to turn off.
Optional Accessories
as being mentioned above, 2 new accessories were also put on the shelf.
the gun mount is made of hard plastic and aluminum. Guns are banned in my country so i'll just so some pics of the mount itself
pocket clip need removing when using this mount
this remote switch has magnetic connection as well, coolest design i've seen so far. It only take seconds to connect/disconnect to the light.
it only kicks the light on constant/temporary High or temporary depending on which mode group you are.
i'm not a expert but believe that kind of UI are perfect for tactical operations.
In case some of you might ask, yes, it's compatible with the M2R.
Beamshots, Runtime and Working Temperature
Beamshots
On the Left: Olight M23 Javelot beamshot (6500k), next to it is the Warrior X (4700k). Very nice tint beam!
The Warrior X's hot spot is a bit smaller than the M23's.
that building is ~ 200m away
Olight M23 Javelot - Turbo 1020 Lumens
Warrior X on Low - 300 Lumens
Warrior X on High - 2000 Lumens
Warmer temperature offers better color rendering. I can't wait to test it in foggy weather.
That signal towel is ~ 150m away
300 Lumens are well enough for almost daily uses. The light offers good runtime as well as less heat working on this modes
While 2000 Lumens are for long range operation.
Working temperature
With the help of larger heat sink plate, this light can handle the heat very well. You won't even notice it warms up when running on 300 Lumens. On the other hand, the head gets to 56 celsius degrees while the body remain holdable.
When off
After running on 300 Lumens for 15 mins
After being left on high for 5 mins. The head got so damn hot, almost 60 degrees. Fortunately, thick head and large heat sink plate dissipated almost heat coming out, hence, the body was not to hot to handle. On other lights with thinner body, the heat transfer through out the light body.
The hottest point of the tube was around 35 degrees.
Runtime
I've heard lot of folks said the step down form 2000 to 600 Lumens in just 1.5 mins was so damn despicable. Well, the lack of the runtime chart on this product has lead to a big misunderstanding. Here is the chart that i've measuresd (using 3000mAh Olight 18650 battery).
Additional detail: This light is featured with vibrating power indicator. Olight out a small motor inside it which generate 3 unique vibration alert at =< 30%, 10% and 5%
It's clearly shown that the Warrior X run on ~ 2000 Lumens for about 2 mins after decreased to ~ 1000 Lumens. It continue putting out ~ 1000 lumens for more than 40 mins before descending and goes off at 77 mins. It's not bad at all!
The low mode, on the other hand, remains almost unchanged during the period of 282 mins before turning off.
77 mins ~ 1.3 hours
282 mins ~ 4 hours & 47 mins
In comparison with the announced runtime.
Conclusions
This light is sweet, i love the design and especially the simple but effective UI. It provides good neutral white tint beam, good throw and usable spill.
However, i hope Olight will improve the switch in the future design (make it more convex). Otherwise, it's one of the best compact-far reaching light out there
:twothumbs:
Specificaitions
- Emitter: XHP35 HI in Neutral White ( i assume it's around 4700k)
- Maximum brightness: 2000 Lumens
- Maximum beam distance: 560m - 1837ft
- Battery: 1 x 18650 high drain battery (included)
- Brightness levels: 2
- Mode groups: 2
- Strobe: yes
- Charging type: tail cap switch equipped with magnetic charger
- Vibrating power indicator feature
- Length: 142mm
- Head diameter: 41mm
- Body diameter: 25.4mm
- Weight: 218g (excluding battery)
- Waterproof: IP68
Unboxing
Impressions
UI
While in group 1:
While in group 2:
Beamshots
Working temperature
When off
Runtime
77 mins ~ 1.3 hours
Conclusions
:twothumbs:
