I received the Trustfire T62 from Trustfire for the review.
The T62 features a XHP70 emitter that can be powered either via 2 18650 or 3 18650.
The T62 comes in this box
Inside the box: manual, 18650 extender tube (to go from 2x18650 to 3x18650), lanyard, spare o-rings.
Here's the T62 in the 2x18650 configuration
And here with the extension for the 3x18650
Here's the XHP70 in the OP reflector
The threads are thick and well done, but come dry out of the box.
The tailcap allows easy access to the mechanical switch, but also tailstands.
UI
The UI is simple, the light doesn't have memory and each time you press the mechanical forward switch, the light turn on at Turbo mode, then cycle between turbo-high -low-strobe-sos, in loop.
Beamshots at 1 meter
Outdoor Beamshots
Output and runtime
All testing was done using 2x18650 2600mAh 18650 cells with PCB.
If you want to see a video beamshot
My thoughts
The light is well built and finished, although the anodisation looks more shiny than the one of other flashlights I reviewed in the past with HA III.
The output is pretty much consistent with the specs, and the regulation is fine, although I am not impressed with the thermal management: when using a fan there is only a small difference in the runtime plots.
With more than 3000 lumen available, I would like to have more levels to have better spacing between the modes.
I am not crazy about having to go through strobe and SOS each time I cycle through the modes.
I wish this light came with a clip, a sheath and in a NW version.
Thanks to: AntoLed, Won, Zampa.
UI
Outdoor Beamshots
Output and runtime
My thoughts
