Gransee
Today, I got a spare moment and did more tests on the Arc4 thermal regulation. My goal is to verify that these units are always operating the LED at a safe level. As you know, temperature is the most damaging factor to LEDs. It affects the thermal maintenance, efficiency, tint and reliability. These are all factors dear to Arc.
So I took a Arc4x which drives the LED harder than a 4+ and performed time/temp measurements on the housing and the LED (the lens was removed so the IR pryometer has a fairly direct shot to the LED die). For all tests, the flashlight was placed on it's side on a wood desk. The pyrometer was aimed directly at the LED and moved around slightly to find the highest reading. Understand that using an IR pyrometer is the most practical method of measuring relative LED temperature once the LED is intalled in a flashlight. Figure that between the die and the IR image out the front there may be as much as a 15 degree gradient worse case.
#0642 4x 3/9/04
00 minutes - 26c LED - 26c housing - L1
02 minutes - 45c LED - 35c housing - L1
05 minutes - 52c LED - 42c housing - L1
07 minutes - 57c LED - 45c housing - L1
10 minutes - 58c LED - 49c housing - L2
12 minutes - 60c LED - 50c housing - L2
15 minutes - 55c LED - 49c housing - L2
17 minutes - 56c LED - 49c housing - L2
20 minutes - 57c LED - 49c housing - L2
Note that housing never went above 51c because the housing is calibrated for a max of 55c. You can also see that the thermal gradient between the LED and the housing is only about 10c, which is pretty good.
The manufacurer of the LED (Lumileds) states in their DS25 doc an average 70% lumen maintenance over 50k hours if the die temperature is kept at or below 90c. Obviously the lower the temp is kept, the longer the LED will last.
Peter
#0642 4x 3/9/04
Peter
