Hello All! Long time lurker that several years ago led me to getting a Fenix LD01 as my first "real" flashlight. In service for a good number of years, in negative temperatures, in water, in engine bays, basically wherever I needed a light. It's been fantastic to me. Unfortunately, this last week it met an unfortunate end after a wash and dry cycle. It's survived this before actually, but this time looks like the LED bought the farm. I think perhaps the O-ring was not sealing as well anymore (it was on its second in about 8 years of service, and certainly looser than new).
Anyways, I'm coming to you all because I know flashlight tech has continued to progress over the years, and wanted to see what options were out there. I read about the LD02, and that the clicky switch should be reliable, but it seems to be getting phased out for the LD02 v2.0. Reading another user's review of it on this site, it doesn't look like I'm going to be pleased at all with the warm light. Looks like it's way too warm.
I say all the above to give context to the recommendations below. I'm actually pretty flexible on most of these things, and happy to be educated where I may be off. I really appreciated the couple of brightness levels on the LD01, and I figure twisty is best because this light is often in my pocket. Run-time is not all that important. Being able to conveniently access it and do tasks is the big thing, and the light itself can get a battery replacement if needed every couple of days. I'd like at least Alkaline and NIMH compatibility, as that's the batteries that are available at various job sites should they be needed. Impact resistance and IPX-8 rating are very important to me. My LD01 has seen some roof drops and submersion. I say my budget is $100 because I beat the crap out of these things, but if spending more would somehow make a tiny AAA EDC even more indestructible I'd entertain it. I say $100 because the Fenix was far less than that (I think I paid $30 for it), so there's definitely room to grow.
Thanks for the help all!
==================Flashlight Recommendation Checklist================
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
_X__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!
____I don't know yet
____Up to $25.
____Up to $50.
__X_Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__X_I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
__X_TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
_X__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__X_I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
_X__I would like a light from a specialty manufacturer (Possibly limited run/Custom).
__X_I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
_X__I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
_X__I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
_X__I want an indoor "blackout" light (15-50 lumens)
_X__I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
_X__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
_X__All Flood: I am doing "arms length" tasks like reading and campsite cooking.
_X__Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
_X__Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
_X__Less than 1 yard/meter (reading, other close work)
_X__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
_X__5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I am searching from a helicopter)
_X__30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
_X__Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
_X__I want a twisty switch (Tighten the head/tailcap to activate, and the light will stay on until the head/tailcap is loosened).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
____A simple on-off with only one output level is fine for me.
_X__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
_X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
_X__Stainless steel (durable, but much heavier than aluminum)
_X__Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
_X__IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
____In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
_X__Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
____Up to $25.
____Up to $50.
__X_Up to $100.
____Up to $200.
____Up to $300.
3) Format:
4) Size:
____I don't know.
6) Manufacturer:
____I don't care
____I don't know.
____I don't care.
____I don't know.
____I don't care.
____I don't know.
____I don't care.
____I don't know.
____None needed
____Holster
