Malkoff
Results 1 to 6 of 6
Thread: Olight M1t tailcap
    Default Olight M1t tailcap
    Has anyone had issues with the tailcap switch
    Being slow/sticky?
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    Default Re: Olight M1t tailcap
    Please don't post duplicate threads ... your other thread was started in the wrong subforum, and was removed.
    Thank you.
    ... is the archimedes peak
    Enlightened Wonder's Avatar
    Apr 2009
    upper midwest
    I have 4 of them with no slow/sticky tailcap switches. I would try to add a small amount of lubrication to the outside diameter of the push button and see if it helps. If not get in contact with Olight as they will surely send a replacement.
    Quote Originally Posted by Wonder View Post
    I have 4 of them with no slow/sticky tailcap switches. The switch on my CU version is not as smooth as the others but not slow/sticky. I would try to add a small amount of lubrication to the outside diameter of the push button and see if it helps. If not get in contact with Olight as they will surely send a replacement.
    my m1t switch has no issues either, but what do u mean with cu ? there is no copper version of the m1t yet..
    So I ordered a m1t from amazon a while ago and the rubber on the tailcap
    switch came off so basically I contacted olight and they said that they have
    one that was returned but didnít say what the problem was so they sent me
    the one I have now with a slow tailswitch. What kind of lubricant do I use and where
    do I put it
    Apr 2009
    upper midwest
    Quote Originally Posted by mortuus View Post
    You are correct. I must have been sleeping at the wheel.
