Al_Havemann
I had an interesting observation yesterday. Since I'd recently received a Vital Gear 2xAA tube to fit my L4 I wanted to see if rechargeable batteries could be used. When I first tried this the head wouldn't even light up. Later I found that I had tried to use a pair of PowerEX 2200's that I'd run flat and not recharged.
Last night I put in a pair that had been charged the previous day. The result was really interesting, they fired up the L4 head with what appeared to be nearly full brightness for about 25 minutes then the output dropped suddenly to about the same as my Inova X5.
Well, that was around 7pm last night and at 4am this morning they were still going, brightness had dropped even more but was still a bit brighter than an ARC AAA. That was 9 hours ago!. I pulled the batteries and ran a quick voltage check, both cells were just slightly over 1 volt.
That's says the head is still operable at 2.1 volts. Pretty impressive for a head designed to take 6 volts.
Another interesting thing about this is that when new, this head would run from a single CR123 for about 40-50 minutes, then dim and run at reduced brightness for another 30 minutes. Now, 6 months later, it will go for 75-90 minutes before dimming. It appears that the electronics have become more tolerant of low voltage with age. Anyone ever heard of this happening?.
Al
Al
