There are many technical fields, and you might be a Tech Guru in one or more of them, but when it comes to headlamps, you really should be availing yourself of the knowledge available here by asking a lot more questions and making a lot fewer statements -- your statements so far are pretty much 100% without basis in facts and science and reality, but so far you seem bound and determined to stick by 'em anyway. You make guesses based on what you think you see, and yell 'em out as if they were facts instead of asking if you've got it right. You get the terminology wrong. You assume your choices are limited to what you think you've understood of what you think you've seen (nobody said you should go back to H6054s!), instead of asking what your options are. You say self-contradicting stuff that makes no sense at all, and won't hear corrections (you point to the fraudulent markings on your headlight-shaped trinkets in your car and say 'see, they're fine!' but then turn around and say you think you've seen the GE LED units on heavy trucks but not the JW Speakers so that means the GEs are legit and the others aren't -- are you running a fever???). You say stuff that's flat-out not true, as evidenced by your photos.
You're very effectively acting as your own worst enemy on the mission to have good, effective, safe, legal headlamps on your car. Which is a shame, because for not very much money or effort you could easily have a very good, effective, safe, legal halogen headlamp setup on your car.
Ignorance is not a moral failure, but willfully, deliberately maintained ignorance is an ugly shame. Some horses that will die of thirst before they'll acknowledge the tub of nice, cool, clean water right in front of 'em, though.
