rrego
Hello all,
Is this a good candidate for return/replacement directly with Surefire?
I picked up a new Surefire G2Z (purchased, returned, immediately by original purchaser (?) - see pics) for a good price on the bay (second hand seller).
Per my pictures (cell phone), the o-ring is pinched and cut at these positions: 11, 1, 3 o'clock. Would this compromise the water tight feature? I don't want to mess with it and just pull the little pieces off, as I want to get opinions on this, if the waterproof feature might be compromised.
I thought I remembered someone posting that they removed the bezel of a Maxvision G2X or G2Z, but I couldn't find it. Does someone remember where that was posted? I'm wondering if the part of the thick bezel is sharp underneath, thus causing it to cut the o-ring/gasket at the three locations or if it was simply tightened too much.
Also the LED is severely off center, the dome is touching the reflector(?). I don't mind the LED off center, since it's Maxvision, it does not mess with the light at all, no hot spot, just cosmetic.
https://imgur.com/a/H0Ng3Sn
