Mar 2, 2019 #1 M marinemaster Flashlight Enthusiast Joined Mar 1, 2003 Messages 1,238 Location Atlanta, GA Does the newest model Strion can be set to low/med/high ? Read the instructions at SL site but looks like it comes High only. Can it be set to turn on to Low from off ? Last edited: Mar 2, 2019
Mar 2, 2019 #2 bykfixer Flashaholic CPF Supporter Joined Aug 9, 2015 Messages 20,448 Location Dust in the Wind Streamlights ten tap programming allows factory setup, (h/l/strobe) hi only, or start on low. Some models programmed to start on low have an added medium then high. I do not know if the newer Strion has the medium option. My older (pre-ten tap) Strion started on high and you held the button down to go from high, to medium to low. Two quick clicks got you a strobe. Last edited: Mar 2, 2019
Mar 3, 2019 #3 M marinemaster Flashlight Enthusiast Joined Mar 1, 2003 Messages 1,238 Location Atlanta, GA Ok cool thank you
