Malkoff
Results 1 to 4 of 4
Thread: Nitecore HC65 - Battery Indicator fault.
    Default Nitecore HC65 - Battery Indicator fault.
    The battery indicator has started to play up.
    It should flash in two groups indicating volts and 0.1 volt.
    When I tighten and loosen the end cap, the blue led flashes 12 + 7 times = 12.7v ???
    Testing on my dvm shows 4.01 v . I know which one I believe.
    Another battery flashes 12 + 9 times. Dvm 4.06v
    Apart from this the headlamp works OK with all output levels working.
    Has anyone else had this problem?
    Default Re: Nitecore HC65 - Battery Indicator fault.
    I've only had mine for about a week, but the voltage indicator seems to work properly when I've used it.
    Ive had mine 3 months with no issues, I would try to raise a return for testing if you have concerns.
    I got in touch with Nitecore support. They gave me a RMA number and I posted the headlamp to China without the battery and headband. I have received a replacement unit which is working OK. Turnaround was 7 weeks.
