I only have one 18650 light for around the property so it doesn't get a ton of use, but I seem to have an over abundance of 18650 batteries.
I'd like to pick up a single 18650 battery to keep in a bag.
I prefer neutral or warmer tints and value hiCRI greatly.
I'm considering something from Malkoff. I'd also consider a larger rotary but that's about out of my price range for a little used light as planned.
Online
2) Budget: An easy question, but you may change your mind after answering the rest!
____I don't know yet
3) Format:
flashlight
4) Size:
Single 18650. Size not important.
5) Emitter/Light source:
LED
6) Manufacturer:
Unknown
18650 rechargeable
Not important.
Not important. I like both.
Short range.
Not important
Slightly important
Any
On/off with high and low. Other levels fine. Moonlight appreciated. Don't care or want special modes.
14)Material/Finish/Coating
Any
15) Water resistance
____IPX4 (Splash resistant)
16) Storage conditions
In a bag or in a car.
