Move heat at the speed of sound
Gravitron
Missouri
New Scientific American article: "scientists watch as heat moves at the speed of sound"
Common graphite, it was discovered, can move heat in a linear direction at the speed of sound. Lots of potential applications for this. It may be possible to incorporate this into the heat management of flashlights. Radiate more heat more quickly and efficiently away from the heat source.
wosser
England, UK
There are many downsides to graphite though. It's brittle and soft and tricky to machine accurately. It tends to degenerate into an extremely fine conductive powder that can find it's way into any nook and cranny (think short-circuits). It would be quite an expensive raw material compared to aluminium or copper, even in low grade form, higher purity would likely be prohibitively pricey.
But that said it does have a proven track-record in thermally demanding applications such as being used to make crucibles for the manipulation of molten tungsten (4000 degrees Celcius or more).
vadimax
Vilnius, Lithuania
No wonder graphite is being used in nuclear reactors :) It is good to have excellent heat conductivity when an alternative is molten radioactive core.
InvisibleFrodo
Synthetic diamond isn't nearly as expensive and it opens up the possibility of shapes and sizes you aren't likely to find in nature
