Acebeam
Page 9 of 9 FirstFirst ... 23456789
Results 241 to 264 of 264
Thread: HDS Pocket Mate? Ode to the HDS EDC Flashlight
  1. #241
    Modernflame's Avatar
    Jan 2017
    Dirty Dirty South
    Default Re: HDS Pocket Mate? Ode to the HDS EDC Flashlight
    Quote Originally Posted by Hogokansatsukan View Post
    . Still prefer the Inkosi over all of them as the lock up is as solid...
    How is the action on yours?
    ďMay it be a light to you in dark places, when all other lights go out.Ē
    J.R.R. Tolkien, The Fellowship of the Ring
  2. #242
    Moderator
    nbp's Avatar
    Dec 2007
    Wisconsin
    Sorry about your Inkosi woes. My buddy and I have small Inkosis and have had very good action on both of them. This is a really good disassembly/lube/reassembly guide I found; it might help you perhaps. I would recommend using the CRK supplied lubricant; itís what Iíve used on all the various CRKs Iíve had with good success. Blade centering being off as you tweak the tension doesnít seem right. Make sure itís reassembled properly.
    http://tacticalreviews.co.uk/wp/?p=684
  3. #243
    Jan 2017
    Dirty Dirty South
    Quote Originally Posted by nbp View Post
    Those are the steps I've been following. It is, after all, a very simple knife to take down. If the pivot tension does not affect blade centering on your Inkosi, then you have a different knife than I have. There has to be a certain amount of tension in the pivot to counter balance the pressure exerted on the blade by the lock bar.
  4. #244
    Moderator
    nbp's Avatar
    Dec 2007
    Wisconsin
    Haha nah man, I know what knife I have. The tension is perfect and the centering is right on. I think something in that knife is wonky. If you canít get the the tension right without the blade thwacking the handle I would send it in and have CRK tune it for you. Thatís not how they are. If it was a Sebbie I would suspect a pinched washer but Inkosis donít use a bushing like that so I donít know what it is but it doesnít sound right.
  5. #245
    Quote Originally Posted by Modernflame View Post
    Action is real nice on mine. I haven't had any issues at all with it.
    Thor's Hammer Custom Leather
    HDS Systems Henry's Mini-Me
    I play with dead things
  6. #246
    Jan 2017
    Dirty Dirty South
    I think something in that knife is wonky...
    Thanks, fellas. I'll just keep working it for a while and see what comes of it.
  7. #247
    usdiver's Avatar
    Feb 2004
    In the Sticks
    I ve had a Benchmade Pardue and a Pro Tech Godson and finally went with the Microtech Navy Scarab as well s the Siphon II. They need to do some tweaking on the Siphons but the Scarab is impressive.
    Donít Tread On Me
  8. #248
    Flashaholic* RCS1300's Avatar
    Aug 2012
    Stamford, CT
    Struggling a bit with my Inkosi. Though I don't require a fast, flicky edc knife, I find the action to be very stiff. I've attempted to remedy this by polishing the washers on a strop and experimenting with various types and amounts of lubricant (e.g. fluorinated grease, Hoppes#9, Nano Oil (10w), Nano Oil (85w), Benchmade Blue Lube, 3 in 1, lithium grease). I'm fatigued with all of the disassembly and experimentation.
    Loosening the pivot screw is not an option because this affects blade centering. If I back off even a little, the blade makes contact with the show side scale. I'm not sure if this phenomenon is common to them all or if it is unique to mine.
    When you combine that with the small, pointed thumb stud that is partially obscured by the finger grooves, you have a knife that frankly unpleasant to open. If there is any moisture on my hand or on the knife, I find that my thumb often slips off the thumb stud half way through the opening process.
    While I admire the craftsmanship and build quality, the Inkosi doesn't log many pocket hours. My HDS family lately been accompanied by other blades...
    Contact Chris Reeve via email outlining your experience and see what they say. Use the majority of this post as your letter.
  9. #249
    If possible, try this lubricant, it is very good, but a little poisonous, if it eat (lead main additive)
    http://www.armitelabs.com/products/M...nti-Seize.html
  10. #250
    Jan 2017
    Dirty Dirty South
    Quote Originally Posted by RCS1300 View Post
    Thanks. I've seen several YouTube videos in which people almost flick their Inkosi's open. Mine is not capable of that. I'm going to give it about three months' worth of opening and closing in the next few days. If that doesn't solve the problem, I'll reach out to them next week.
  11. #251
    Flashaholic* lion504's Avatar
    Feb 2016
    Delica 4 in M390 with my trusty High Noon.
    299,792,458
    My Lights
  12. #252
    Jan 2017
    Dirty Dirty South
    Quote Originally Posted by lion504 View Post
    That's a killer combination. My High Noon has also recorded a lot of pocket time lately. I enjoy it so much that everything else has been staying at home.
    Love the M390! How is the factory edge? My PM2 came with an adequate, albeit toothy edge. Wasn't terribly impressive.
  13. #253
    Feb 2016
    Factory edge is great. The primary edge/bevel is much wider than normal. Really like it. Overall F&F is really nice. The Delica displaced my BM707, which is saying a lot since I really love that knife (the 707). Very happy they decided to do this special edition D4.
    299,792,458
    My Lights
  14. #254
    usdiver's Avatar
    Feb 2004
    In the Sticks
    Donít Tread On Me
  15. #255
    peter yetman's Avatar
    Mar 2014
    North Norfolk UK
    I'm sorry, I laughed out loud and interupted the Wimbledon coverage.
    "Tactical" Beard Comb?
    I didn't even know there were Beard Combs, let alone Tactical ones.
    Sorry Steve, you've made me giggle.
    P
    Peter's shopping list:- HDS / Oveready 170N Exec/LE and an Oveready V4 Nichia Drop In. Otherwise I'm content. Want want want, that's me.
  16. #256
    usdiver's Avatar
    Feb 2004
    In the Sticks
    Obviously there is P
    I m happy that made you giggle.
    Donít Tread On Me
  17. #257
    Jan 2017
    Dirty Dirty South
    I'm pleased to report that I've resolved the issues with the action on my Inkosi. Just needed more breaking in. While I have acquired a few more blades, this CRK knife has resumed it's place as my primary HDS pocket mate.
    Cheers
  18. #258
    Moderator
    nbp's Avatar
    Dec 2007
    Wisconsin
    Now that is good news!!
  19. #259
    Mar 2014
    North Norfolk UK
    That's very pleasing.
    P
  20. #260
    Cheers
    Most excellent. You need to develop CRK thumb for a week or so, then all is good in the matter separator world of CRK.
  21. #261
  22. #262
    Moderator
    Feb 2003
    CA
    Would be good if you id your images. Thanks.
    Bill
  23. #263
    Quote Originally Posted by Bullzeyebill View Post
    Bill
    The knives are a Shirogorov Neon Lite and a SAKModder custom Yeoman.
  24. #264
    Spyderco Chinook 2
