I use a flashlight at work, its on about 2 minutes at a time several times a day.
Recently bought a Maglite Pro. It has good light output, but goes through about 4 alkaline batteries per week. I switched to 2000mah eneloops, its bad, almost unusable. Have to recharge before the day ends.
I tested the current draw of the Maglite Pro, its 1.75 amps, which I guess explains the short battery life.
I tested my old Maglite Multi Mode flashlight. Its current draw on the high setting is .250 amps. Although it does not have as much light output, its still decent for my purposes. Theoretically, the eneloops should last about 8 hours. I'm going to try it this week.
I also tested a Coast G25, on high setting, it draws 1.7 amps, on low it draws .250 amps. For the amount of current it draws on low, its somewhat brighter than the Maglite Multi Mode that draw the same amount of current.
The Coast has a different lens, like a magnifying lens that maybe makes it seem brighter for the same current draw.
Question is, for a given amount of battery current draw, lets say .250 amps, is there any guideline on what would be the brightest led/lens combination aa flashlight?
Thanks.
Thanks.
