Klarus
Results 1 to 20 of 20
Thread: Single AA light, clicky tailcap, NO MODES? (on tailcap switch at least)
    Default Single AA light, clicky tailcap, NO MODES? (on tailcap switch at least)
    Do these even exist in 2019? It's just about impossible to search for a flashlight that just turns on and off at the tailcap switch. I loved my Fenix E11 but sadly it's been lost and I can't buy the same model to replace it. The E12 looks the same but has irritating mode switching on the tailcap switch. (Can this be modded out, perhaps?)
    It's awesome that lights are getting brighter every year, but the fiddliness that comes from the on/off switch having to do double duty is a huge step backwards IMO.
    Aug 2013
    Land of the rising sun
    Default Re: Single AA light, clicky tailcap, NO MODES? (on tailcap switch at least)
    The Streamlight Protac 1L-1AA has everything you are looking for and not too expensive, it can be programmed to High only, 150 lumens on 1AA.
    It's a pretty good light, I EDC'd mine for about 18 months before I switched to a better light, had no issues during that time and I still carry it as a backup in my bag.
    Other even cheaper options are:
    Coast HP1
    Coast HX5
    They are both 1AA and single mode, tailcap switches.
    Also:
    Fenix LD12
    Tailcap switch and with mode switch on the side, never touch the side button and it will be left in the output that you set. At least you have some options with the output levels with this light.
    - I don't make fanboy recommendations, if I recommend a light it's because it's the most practical option for your intended application.
    - Whatever light you carry, no keychain should be without a Photon Micro-Light II.
    Aug 2013
    I just remembered about another cheap option that fits all your requirements:
    NightStick Mini-TAC - 1 AA
    https://www.baycoproducts.com/produc...al/item/mt-110
    Sounds like the Fenix LD12 (might go with the LD22 instead) is what I'm looking for. Thanks!
    The Thrunite Archer, Fenix LD12, and several others have the power switch on the tail and the mode switch on the side, with mode memory. That's effectively single-mode if you don't press the mode switch while it's on.
    Ceilingbounce - flashlight testing and runtime graphs for Android
    Quote Originally Posted by GoVegan View Post
    Coast HP1
    I can second the HP1 as a great cheap option... this is about $7.60 on Amazon right now and I have yet to find a better 1xAA single-mode tail clicky for that price. I've bought 5 of them for family members so far, they've been surprisingly good for the money.
    If you want to spend more, the others listed in this thread are also good of course, and I'd add that you consider the Streamlight Protac 1AAA 88049 too -- it's obviously not AA, but it's a great little robust AAA that is larger than many AAA flashlights and rotates in with my AA flashlights just fine, and is honestly one of my favorites in its general size category. It's about as long as some AA EDCs, but a little thinner and programmable to meet your single mode requirements like its bigger AA Protac brother. It has a dual-mode that is super-useful too.
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    Peak El Capitan, but the plunger switch is momentary, not a "clicky" ... twist bezel for constant-on
    ... is the archimedes peak
    Flashaholic* Paul6ppca's Avatar
    Jun 2006
    RI
    You could use Eagletac AA with the head tight you will always get high mode.
    Anyone have experience with the Nitecore MT1A/MT2A? It looks like the tailcap switch is full power only with the bezel fully screwed down, which is good enough for me. Looks/price/availability look appealing.
    Quote Originally Posted by Agent VX View Post
    I haven't figured out how that UI is supposed to work.
    Quote Originally Posted by Paul6ppca View Post
    Which AA exactly?
    The one that I have can give High or Strobe when tight and that is not a surprise that I like at all.
    Jun 2006
    RI
    You are right the Eagletac D25 will enter strobe if tapped 2 times.
    I use it without issue. I like that I have high and with a twist I can have low.
    Pretty good compromise.
    Unless what you want is a single mode light.
    I like a light like this also. I have a D3A, which is identical electronically to the Eagletac D25 Mk II. It has turbo and strobe, and then you have to twist the head to access all the other modes. You have to half press to get to strobe once on, so itís a pretty good compromise, as itís difficult to accidentally activate strobe. The nice thing is you can access the other modes when you need them, and they do come in handy.
    Quote Originally Posted by Berneck1 View Post
    Yeah I really like mine too but this is not what the O. P. says that he is looking for,in fact it reads to me that this is why he wants a single mode light!
    Quote Originally Posted by AVService View Post
    Yeah, thought it might be a decent alternative. Any single mode lights I know are typically of low quality....
    I hear you,this is sadly true.
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    Malkoff MDC 1xAA tube + VME bezel + dropin of choice ?
    I use a variation of this (in titanium) ...
    It is a single AA, single mode torch. I think this one is currently hosting an M30WF, but something similar could be done with the modern range of M31 series dropins.
    Thanks for the suggestions, everyone. I ended up going with the Nitecore MT2A (2xAA instead of 1xAA, but the MT1A would have been pretty much the same). What I really like about it is with the bezel screwed fully down it **ONLY** turns on and off with the tailcap switch, and the "user-defined mode" you access by loosening the bezel remembers what mode you used last. That means if you carry it with the bezel always screwed down it won't ever shift modes on you, but you can still access other modes by loosening the bezel. (I would frankly like to see strobe/sos/etc. modes banned by law from all flashlights though, but good luck with that. The gimmicky modes are here to stay because they cost nothing to add.) The Eagletac looked appealling at first, but having strobe mode accessible from max output mode would have pissed me right off.
    Also that Malkoff MDC looks great and might well be my next light. (I've no fear of modding. Although the one downside of the MT1A/MT2A is that they've apparently got tons of red loctite on the threads inside the bezel. Boo.
    Flashaholic pc_light's Avatar
    Feb 2004
    Garden State, USA
    Didn't see this thread previously but I might have suggested the Sunwayman R15A -single mode, single AA, tail clicky, 90 Lumens and on sale now at Battery Junction. I don't own one though and can't vouch. I came across it while I was searching for a similarly configured host for a mod.
    Nitecore MT2A (and MT1A) sounds like a great light for its simplicity.
    BTW, welcome to CPF.
    "may you live light and phosphor" - Mr. Spark
