I think the main reason you don't see many SST-90 are that they old and outdated. Modern LEDs like XHP 70.2 are considerably brighter and cheaper.
As far as the flickering effect you described, that sounds like slow PWM (Pulse Width Modulation). PWM is controlled by the driver, not the LED. It is a way of getting lower brightness settings by strobing the LED on and off very rapidly. Most quality modern LED flashlights use high-frequency PWM that isn't visible to the naked eye and is much more pleasant to look at. But your light might be an older one that still uses low-frequency PWM.
