NEXTORCH - 300 m long-shot E6
Results 1 to 22 of 22
Thread: Why do flashlight get anodized?
    Nov 2008
    Italy
    Default Why do flashlight get anodized?
    I was wondering what the purpose of anodizing aluminum flashlights is. AFAIK aluminum doesn't get attacked by water or air (doesn't rust and doesn't develop any kind of patina) so... why do we need aluminum flashlights to be anodized (any type and color of anodizing)? Do we need it in the first place?
    Preon Stealth Black
    Default Re: Why do flashlight get anodized?
    It isn't strictly needed; there are plenty of plain aluminum lights out there doing just fine. Anodizing increases durability and helps with aesthetics. Also it is sometimes it is used to block electrical path through threads so that loosening the threads causes mechanical lockout.
    Also aluminum can definitely corrode, just take a look at Land Rovers from the 60s. Not really relevant to flashlights though, unless it's a dive light.
    Hello darkness my old friend,
    I've come to talk with you again...
    I liked neutral tints before they were cool.
    Flashaholic* thermal guy's Avatar
    Jan 2007
    ny
    One reason is the looks. Ever seen a stripped aluminium light? Some like the looks but definitely not my style.
    If i had one day left to live i would want to be at my workplace.Because every day is like a frickin eternity.
    That's one of those questions that causes some to say "hhmmmm"....
    John 3:16
    Flashaholic* Timothybil's Avatar
    Nov 2007
    The great state of Iowa
    It's my understanding that it also protects from dings and scratches. That is why you will see peo0ple making a distinction between HA II and HA III anodizing, with HA III being stronger. Also, it is practically the on ly way to apply color to an aluminum light. One could paint it, but paint can rub or flake off a lot easier than anodizing does.
    Remember, Two is One, and One is None!.
    Nov 2015
    Powder coating metals is usually cheaper, but sits on the surface and rubs off with wear. Anodizing embeds color deeper into the actual metal and is significantly more durable to keep it's color even when scratched. I also find that anodizing is less prone to leaving fingerprints. Shiny surfaces are nice when kept clean...
    Sent from my Pixel using Candlepowerforums mobile app
    Nov 2007
    New question. What exactly is ceracoating, and where does it fit in this discussion?
    Flashaholic* Thetasigma's Avatar
    Nov 2015
    Michigan, USA
    Quote Originally Posted by Timothybil View Post
    Assuming correctly done anodizing and cerakote.
    Where anodizing is an electrochemical process to produce a controlled oxidation of the aluminum to generate a very durable layer of aluminum oxide that is chemically bonded to the aluminum, cerakote is a ceramic based finish that is carefully applied to the part to be finished. Cerakote is essentially a paint so it is only as impact resistant as its base material, in this case aluminum is somewhat easy to flake cerakote off on impact. Cerakote IMO makes more sense on firearms or steel parts where the base material is harder than say an aluminum light.
    As for general comparison, anodizing can be more durable to wear and impact but especially the stronger HA type III, is quite limited in what sort of colors you can get. Cerakote while less durable has a plethora of color options available, for example you could get a pink and zombie green on the same light if you really wanted to, anodizing is going to be a singular color as it is colored by dyes in the chemical bath entering the pores and being sealed in.
    Administrator Kestrel's Avatar
    Oct 2007
    Willamette Valley, OR
    My apologies for the interjection of a clarification; there are no such things as HA II or HA III.
    There is Type II anodizing; Type III is also called HA.
    HA-III is sort of like saying Roger-Roger or Pizza Pizza.
    I like black type lll HA personally because of the way it looks. There is going to be differences even among the type lll HA's though. From Surefire to Elzetta to Malkoff, they all differ. I like Malkoff the best myself, but some old 6p's are very nice too. Does one "need" an anodized light? Maybe not. Depends what you like and what your doing with the light. If you get a colored Elzetta Limited Edition light, they are first anodized type lll HA then ceracoated over the top of that.
    Jan 2007
    ny
    I donít even think any but the cheaper lights use type II.i plasma coat for a living and have always wanted to coat one of my lights. Problem is thermal spray doesnít take to well to impact. As far as wear. They do not ever wear. Not with hand use anyways
    There is also the PVD process that could be construed as similar to powder coat or cerekote where the coating is in a gasious state and electrically bonded to an electroplate of material(s) over the alluminum. Foursevens blue Paladin and PK's PR-1 used that process.
    John 3:16
    Nov 2008
    Norway
    Aluminium does corrode. If you own a alu boat, and dont change zinc anodes, well the boat will sink Also i dont consider bare alu as clean, put bare alu in your pocket, and your pocket will turn black over time. if you rub bare alu at a white wall, it will leave a mark, just like a pencil.
    Quote Originally Posted by thermal guy View Post
    Oh...I don't know.
    So far so good.
    John 3:16
    Nov 2015
    Michigan, USA
    Quote Originally Posted by Kestrel View Post
    Thanks for the clarification.
    Bare aluminum will turn your hands black if you handle it a lot. Anodize is very durable and while you need to get it off of electrical contact surfaces because it's non-conductive it improves the thermal conductivity of aluminum. That's never a bad thing on a modern light.
    Quote Originally Posted by focusworks View Post
    This last bit is most interesting. Would you mind elaborating on it? How does it improve the thermal conductivity?
    There is also the aesthetic value of anodizing. Look up tjís custom gunworks to see some of his work with anodizing
    a single sunbeam is enough to drive away many shadows- St. Francis of Assissi
    Quote Originally Posted by Skaaphaas View Post
    No blanket on the outside. The anodize coating could act as a thin layer of insulation. I say could because some desingers build their ideas around the properties of the annodize layer to achive a more efficient conduit.
    John 3:16
    Jan 2014
    Blue Ridge Mountains, VA
    Anodizing done in batch processing is extremely cheap to perform.
    The military process Mil-A- 8625 type III is typically a natural color finish which varies from tan to olive green. Black anodizing is a dye added to the sealing operation.
    Type III anodizing is a minimum of .002Ē thick and is done for abrasion resistance first, then corrosion resistance secondly. .002Ē doesnít sound like a lot of thickness, but thatís per surface, so threads arenít the best thing for type III.
    As for Ceracote, iíd do KG Coatings Gunkote instead. Can be performed at home and if you select the 1000 series material, itís room temperature cured.
    Lauer Firearms offers a coating called Duracote. Duracote is Sherwin Williams Polane repackaged at five times the cost.
    Those that can, do. Those that can't, teach.
    Black anodized aluminum has significantly better emissivity than bare aluminum and better than oxidized aluminum hence it will run cooler ... It dissipates more heat.
