Does anyone have this light that could answer a couple questions?
I think I have a couple problems.
First one: does the side button have the battery charge indicator like other Olights? Like my S1R Baton II when you press the side button it turns green unless the charge falls below 60%, then it turns yellow. At 10% or less it turns red. It's not illuminated at all on my new M2R.
The second one: according to the website the Lumen modes should be 1 > 15 > 60 > 250 > 700 > 1500
If I press and hold the side button I get the 1 lumen. Then if I keep holding in the side button, it will cycle through 15 > 60 > 250 > 700. Then I would think if I double tap that side button it should go to 1500. However nothing happens. It just stays on 700. And when I press the tail click, it is no brighter than 700.
So I think the turbo mode is non existent and there's no battery level indicator.
Could someone confirm if theirs is like mine or if theirs is as I expected mine SHOULD be?
Thanks!
Sent from my iPhone using Tapatalk
Thanks!
