shipwreck.
- Joined
- May 21, 2019
- Messages
- 35
I could've sworn, when I first got my 6P in 2006 its packaging stated a 600 lumen output. Now 12 years later, amazingly my lamp assembly finally burned out!
I tried getting an LED replacement for more lumens, runtime, overall lifespan, rechargeable 123A compatibility, etc. and I can't find any surefire brand product that's specific to the 6P. Looks like there's just a gross lack of support for the product from surefire. The only surefire brand LED conversions I can find are not for my light PLUS are grossly overpriced, replace the whole head AND cost as much as whole new light. So that's would be a no go even if it were compatible.
Why can't they just literally put an LED in the exact same drop in assembly?
So I settled for an off brand product that claimed compatibility. But when it arrived I found it doesn't even fit in the head. I can still put the bezzel on but the drop in is too wide at the end/doesn't taper correctly to sit all the way down flush. So the drop in protrudes from the body a little and the bezel can't screw down all the way. Probably not water resistant anymore. Ugh.
Anyway. On top of that although it claims like 1200 lumens or something it seems DIMMER than the original that was supposed to be 600. It's very short ranged and doesn't even outshine like parking lot lights at it's brightest point at close range so it's just trash.
So I gave up and decided I'd just get an original incandescent 6P lamp since that's what I got best performance from anyway. But the Surefire P90 that looks like the thing I need states only 65 lumens??? And that's just sounds TOO weak??? Plus I could've sworn my original 6P was 600 but I can't find any surefire brand drop in that puts out as much. So what's going on here?
I did find a P91 that puts out 200 lumens so I guess that'll do but is it compatible with the 6P???
Also is there any way to regulate voltage with a drop in component(body?) that would allow me to use rechargeable 123As with incandescent???
