The Fenix-Store
Results 1 to 7 of 7
Thread: Sauna LED Lights Any danger of failure?
    usdiver's Avatar
    Feb 2004
    In the Sticks
    Default Sauna LED Lights Any danger of failure?
    Working on a project and would like to know about something I stumbled across
    LED light panel... thinking of putting it in the corner in one room (where the stove and rocks are) and covering with this
    I know the wood will be fine but I m concerned about this particular LED setup seeing as how it will be in a hot humid environment.
    Donít Tread On Me
    Default Re: Sauna LED Lights Any danger of failure?
    Depends on the exact specs of the lights you will be using but as long as all parts of the circuitry that will be exposed to the sauna environment are contained within water-proofed enclosures and the LEDs themselves are quite heat resistant there should not be any problems.
    Obviously the issues you could face are moisture shorting the circuit or too much heat to the chip from the sauna and the chip itself being on. As long as the chip heat is moved away from the chip itself the ambient temperature should not cause it to fail.
    usdiver's Avatar
    Feb 2004
    In the Sticks
    Thanks for the response, only just now saw it but vapor proof lights were purchased. I could have chosen better but difficult when you live in the sticks and the nearest civilization doesnít have much to choose from.
    Donít Tread On Me
    usdiver's Avatar
    Feb 2004
    In the Sticks
    Still working on this
    Thanks again SD
    Donít Tread On Me
    Are these vapor proof lights powered 220 volts?
    usdiver's Avatar
    Feb 2004
    In the Sticks
    Yes buddy (E.U.) spec
    Donít Tread On Me
    usdiver's Avatar
    Feb 2004
    In the Sticks
    Can someone close this please...
    Donít Tread On Me
