DayofReckoning
I have a few questions, and am looking for a few tips in regards to reducing resistance as much as possible in a few incandescent lights I have. Resistance seems to effect them more so than LED's, and I'm trying to eek out as much runtime and lumens as I can.
My newest light, a Fivemega 1X26650 E Body, requires a spacer for the 26650 cell to work. Currently, I am using the tailcap spring from a Mini Maglite to make contact from the battery to the small brass nipple that is located on the bezel. It works just fine.
1. Would using a magnetic battery spacer, like those used in converting flat top battery's to nipple top, have any measurable difference in resistance versus the tailcap spring like the one I'm using?
2. McClicky switches come in Copper, Brass, and [FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]aluminium. Has there been any testing done on resistance between these switches?
3. Other than keeping the threads as clean as possible, and keeping lube contained only to the orings, is there anything else that can be done to further reduce resistance? [/FONT]
