HKJ
[size=+3]Vapcell INR16340 800mAh (White)[/size]
Official specifications:
This is a CR132 equivalent size, but the voltage is always compatible.
The two cells do not match completely, but it is not bad for this size battery. The battery can easily deliver 3A, but it pressed above that.
Internal resistance measurement by pulsing 0.5A on/off.
[size=+3]Conclusion[/size]
This cell has good capacity and can also deliver current, especially for a 16340 size.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
- Model: INR16340 800mah 7A
- Size: 16.4*34.0mm
- Type: button top
- Nominal voltage: 3.60V
- End-of-charge voltage: 4.20V
- End-of-discharge Voltage: 2.5V
- Typical Capacity: 800mAh (0.2C discharge)
- Min capacity: 750mAh (0.2C discharge)
- Weight: Max:20g
- Internal resistance: Max:20mOhm AC 1kHz
- Standard Charge: 500mA,CCCV 100mA cut-off
- Quick Charge Current:1000mA
- Max Continuous Discharge Current: 7A
