I came across this scientific paper: https://www.mdpi.com/2313-0105/2/1/3/htm (full text and PDF are free, just click the link).
In the last section, it states
Does anyone have any information about this?
I couldn't retreive the original paper that describes the 33% SOC method, however I have this anecdote from personal experience:
I had a pair of Sony AA 1800mAh NiMH batteries, about a decade old, that had degrated to the point where a charging voltage of 2.5V was needed just to force 0.5A through them. Internal resistance measurements were around 1500mOhm (Opus BT-C3100). Running the refresh cycle on the Opus at 200mA (it does three charge/discharge cycles per refresh) didn't improve the performance.
I put it on my hobby charger, gave it 2000mAh at 0.5A until the cell reached 60°C, discharged it at 1A down to 0.3V (tapering off down to 0.1A at 3V at the end of charge), then charged it at 100mA for 16 hours and did another 1A discharge. At the end of this, the internal resistance fell to 1100mOhm, and the charging voltage for 0.5A charge current fell to 2V (down from 2.5V). This improvement was after 10 charge/discharge cycles at 200mA on the Opus.
There seems to be some merit to the method described in the paper. Holding the battery at 60C isn't difficult using a high-current charge while the cell is in some sort of makeshift insulator (like a clean rag). Low-rate cycling is easy with a hobby charger. I'm not sure what they mean by 33% SOC - it could mean cycling 33% of the total capacity in and out (594mAh for my 1800mAh cell), or it could mean cycling the battery up and down keeping the average charge level at 33% (e.g. cycling repeatedly between 23 and 43% full).
Anyway, let's start a discussion - does anyone else have some experience or methods that worked for them for reviving old NiMH cells?
"After long-term storage, a few small-current charge/discharge cycles can bring back some of the lost capacity in Ni/MH batteries [322,323]. A more complicated method proposed by Li and Meng [324] involves 33% SOC small-current charge, high-temperature storage (45–60 °C for 20–24 h), and a small current charge/discharge cycle to restore at least part of the lost capacity. Its strategy is to redistribute the Co-conductive network that was destroyed during storage."
