Klarus XT2C button replacement - RESOLVED :)
Hi,
I bought a Klarus XT2C in 2013. Maybe due to usage, the mode part of the rubber button of the tailcap was torn off, exposing the toggle switch.
I'm from the Philippines. I have contacted the local distributor, but is slow to reply and seems disinterested. I also contacted the Chinese customer service (Shenzhen, GD, CN) who had indicated that while my light is beyond the warranty period, they will have to check with their local dealers to see if they still have this part(s) for sale.
In any case -- I am looking to buy the rubber button, or the tailcap itself. I did found tailcaps of Klarus XT11 listed for sale. Will this work on the XT2C?
Thanks.
Reason: edited title to reflect resolution of problem
Re: Klarus XT2C button replacement
Originally Posted by
akula88
Hi,
Thanks.
Honestly, I'm not sure. Your's is an older light and there might be differences in threading to keep them from being compatible...I KNOW a newer tailcap will not be because the different LED being used and because the UI has been significantly changed to make it impossible to interchange them. I believe that there is some circuitry within the newer tailcaps to accomplish the newer modes and they are not simply make or break switches.
I wonder though if you could effect a repair using liquid electrical tape, or perhaps some silicone.
Reason: <edited to conform to advice of moderator>
Moderator
No posting "cut-and-paste" private communications here on CPF please
... is the
archimedes peak
Thanks for the clarification, KLight. I'll get back to Jenifer.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Bookmarks
