Malkoff
Results 1 to 1 of 1
Thread: Two Zero Tolerance Dmitry Sinkevich sprint run knives 0452WBW & 0450G10
    Oct 2015
    Lancaster, PA
    Default Two Zero Tolerance Dmitry Sinkevich sprint run knives 0452WBW & 0450G10
    1) LNIB ZT 0452WBW
    The original Zero Tolerance 0454 was an award-winning collaboration between ZT and custom knife designer Dmitry Sinkevich. But it was also a very Limited Edition knife.
    To make this amazing knife more readily available, ZT has created a new-for-2015 version based on the original’s streamlined form and high-performance function. The 0452WBW is the same size as the original 0454, but with a carbon fiber front scale and S35VN dual-finished blade. S35VN sharpens to a razor edge, holds it, and can be resharpened easily. The 045WBW opens as smooth as butter with the KVT ball-bearing opening system and built-in flipper. A titanium frame lock with hardened steel lockbar insert ensures solid lock up
    As a final touch of class, the 045WBW features handsome 5-spoke pivot hardware. From office to outdoors, the 0452WBW is ready to go wherever you're ready to take it.
    This BlackWash
    blade, white carbon fiber version of the 0452 is a sprint run, built in limited quantity.
    Made in the USA
    Based on the award-winning 0454
    Lanyard hole
    Flipper
    Frame lock
    Reversible deep-carry clip (left/right, tip-up)
    Steel: CPM S35VN, BlackWash
    finish
    Handle: Carbon fiber front, titanium back, BlackWash
    finish
    Blade Length: 4.1 in. (10.4 cm)
    Blade Thickness: 0.156 in. (0.396 cm)
    Closed Length: 5.2 in. (13.2 cm)
    Overall Length: 9.3 in. (23.6 cm)
    Weight: 4.3 oz. (122 g)
    This knife is like new never carried never used to cut anything.
    I am asking $215 shipped
    LNIB ZT0450G10
    Based on the streamlined form and high-performance function of the original ZT + Dmitry Sinkevich collaboration—the 0454—and on its more-compact cousin, the 0450, the 0450G10 sprint run knife comes with a handsome G-10 front scale.
    The G-10 gives this 0450 a discreet look, while its 3.25-inch blade and lightweight-yet-stronger-than-steel titanium frame, make it an easy-to-carry EDC.
    ZT built the 0450G10 with an S35VN stainless blade that sharpens to a razor edge, holds that edge well, and then can be resharpened easily. The knife opens smoothly and easily with our KVT ball-bearing opening system and built-in flipper. A titanium frame lock with hardened steel lockbar insert ensures solid lock up, too.
    This G-10 edition of the 0450 is a sprint run, built in limited quantity.
    Specifications:
    Made in the USA
    Manual open, KVT ball-bearing system
    Frame lock
    Reversible (left/right) clip
    Steel: S35VN, stonewashed & satin finish
    Handle: Titanium, stonewashed finish
    Blade Length: 3.25 in. (8.3 cm)
    Blade Thickness: 0.121 in. (0.307 cm)
    Closed Length: 4.1 in. (10.4 cm)
    Overall Length: 7.4 in. (18.8 cm)
    Weight: 2.6 oz. (71 g)
    This knife is also like new it was carried once but never used to cut anything.
    I am asking $140 shipped
    If you have any questions please send me a pm.
    Do not post in the thread.
    I do not accept paypal.
    I prefer a USPS money order, and I will ship immediately after receiving it.
    I will also accept other money orders or personal checks but will only ship after they clear.
    Thanks for looking,
    Mike
    Attached Images Attached Images
