Malkoff
Results 1 to 7 of 7
Thread: Acebeam W10 vs Weltool W3
    Au Acebeam W10 vs Weltool W3
    Trying to decide on a good long range thrower I can use to point out a flying quad or a waypoint in the woods. As I understand it the specs are very similar, W3 is slightly more expensive and can use a smaller body. W10 comes with filters I'll never use and a strike bezel I will forget and tsa will steal from me. Any major differences in performance of the two I am missing?
    Sep 2018
    Mostly California
    Default Re: Acebeam W10 vs Weltool W3
    I have all of the generally available LEP lights. W3 and W10 are similar in performance, with a slight edge in throw to w10 (but color differences could account for that).
    I'd be fine with either if I was forced to keep only one, but given the choice I'd prefer the w3: better look/feel in my hands, short tube option gives a throw/size ratio that's untouchable.
    Awesome, thank you. The A10 is about $50 cheaper. I would never use the short tube option of the W3. I will probably go for performance edge or at least the cheaper option for like performance. Feel in the hands is a little steep of a jump for $50.
    Any other lights int hat size with similar or better specs I should also consider?
    Sep 2018
    Mostly California
    Quote Originally Posted by chikendinner View Post
    None that I've seen - all the rest are much larger.
    I ordered the weltool W3. I was about to order the acebeam but it looked too gimmicky and unrefined.
    Let us know how it performs for you.
    Flashaholic* Alex1234's Avatar
    Jan 2010
    Bear Delaware
    w10 has more performance then the W3. It has a bigger battery and is rechargable via USB type c. To me the W10 is more refined also it's a decent amount cheaper . But the W3 looks great as well. However stock preformace falls below spec.
    Flashlights: X65vn,Tn42vn, Boss1vn, X6vn SSCU, X5 kronos, U21vn, m43vn, FD41vn, SDminivn, H20vn, E01vn, Catapult v5, Bkfa09s, XT15, S10R Baton III, 55w hid spotlight 1,100,000cd
