Malkoff
Results 1 to 11 of 11
Thread: High CRI 1AA light
    Default High CRI 1AA light
    I'm looking for a high cri light that uses 1AA or 2AA battery. Prefer 1AA
    Would like it to be titanium, brass or copper but happy to consider other materials like steel, alu, etc
    I don't want a flimsy on off switch like the one Zebralight uses. The last Zebralight I bought lasted less than a year then the switch broke
    Prefer it to be able to stand upright when on
    No magnet
    Prefer the beam to be more floody than throwy, it's for indoor use and garden use
    Budget is around 200 £/$ but am willing to consider higher. If higher, I'd want it to come with some kind of warranty if possible and last for at least a few years
    If a good high cri light isn't available, then would be willing to consider a warm white
    I have a Eagletac 1AA D3A Nichia 219C and it's beam hotspot and corona is too narrow
    peter yetman's Avatar
    Mar 2014
    North Norfolk UK
    Default Re: High CRI 1AA light
    What about an El Capitan from peakledsolutions.net?
    Aluminium, Stainless or brass. Single AA. High CRI. Built like a brick outhouse. Made by the people that answer the phone and emails. Good warranty.
    Simple head twist for on and to increase brightness.
    P
    Peter's shopping list:- HDS / Oveready 170N Exec/LE and an Oveready V4 Nichia Drop In. Otherwise I'm content. Want want want, that's me.
    I have carried several different ZL every day for over 8 years and never had a switch issue and have to think that your issue was not a common thing for them at all.
    I have read of a few others but this is far from the norm and they do not have that reputation at all I will say.
    I really like the Manker Right Angle head lights and the AA version is sold in a 219b and is in my 5th pocket most days since getting mine.
    Mine has a floody beam that I find pretty useful.
    Quote Originally Posted by zeally View Post
    I have the Maratac 1AA in copper. Countycomm has the titanium version of this light in stock right now. A simple, rugged torch with 3 modes of high CRI light--worth considering.
    Quote Originally Posted by peter yetman View Post
    How much more pressure is put on the battery when it turns on and you keep twisting in to increase brightness? Does the pressure on the battery stay the same or does it compact the battery even more?
    They don't answer all emails. I emailed them last year to ask for some beamshots, they never replied.
    The El Capitan uses a Cree XPG3 R3 Hi Cri. Does it have a narrower beam hotspot than an XM L2 led and Nichia 219B?
    Quote Originally Posted by AVService View Post
    I really like the Manker Right Angle head lights.
    Sorry, I should have said. I can't get a light with a magnet in it. This head light is nice but unfortunately it has a magnet in the tailcap
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    I agree that the Peak El Capitan (or Logan 17500) may be a good choice, but please see my responses below ....
    These type of twisty switches are called "battery-crushers" for a reason
    More pressure = more brightness, with QTC.
    You may well prefer a fixed-mode (non-QTC) version instead, available by custom request.
    I have often wondered if Peak may use an aggressive spam filter, as some seem to find this, while others say they are very responsive
    Personally, I have dealt mostly with RMSK (their main distributor) who I have found to generally be very easy to reach.
    Also ... they are unlikely to provide beamshots, but instead refer you to their informational forum here on CPF.
    https://www.candlepowerforums.com/vb...-LED-Solutions
    A search of that subforum should yield examples of the beamshots you seek
    All emitters in the small "pocket lights" by Peak I find to be moderately floody, even their "narrow optic" version (which is now standard, I believe)
    At one time, other options were available by request, but for that you would need to check with Peak direct.
    ... is the archimedes peak
    Jun 2003
    SF Bay Area
    The Countycomm Martac AA and AAA lights all of a light spring in the bottom of the tube. They are not "battery crushers".
    The "switch" is the tube collar screwing into the head, where there is a circuit board and "ring" of copper where the body's collar touches the ring.
    To change levels, unscrew and screw back in to change (like a clicky switch). No memory. My lights are Med-Low-High (back to Med)...
    Brass versions have the best thread. Copper and Titanium threads are rougher but still work fine. Aluminum works fine too. Countycomm tends to run lights in batches and they have "random" availability in different materials. Flat bottom, no magnet.
    Countycomm also has a "peanut" light (rechargeable). This is a two two level light. There is a "dome" switch in the base of the board. First contact is low, tighten to press dome, for high.
    -Bill
    I have the AAA Aluminum version in CRI and I like it but unfortunately the clip broke in like 3 weeks and thus its been sitting, but it's a huge improvement from their first generation lights. Very good feel and threads are smooth and it didn't cost too much as they run sales alot.
    Sent from my SM-G955U using Tapatalk
    Mar 2014
    North Norfolk UK
    Here you go, the Haiku if you're quick!
    https://www.candlepowerforums.com/vb...Haiku-for-sale!
    It'll last you the rest of your life, maybe the ultimate EDC.
    P
    Quote Originally Posted by archimedes View Post
    I emailed Peak 5 days ago but didn't get a reply, so I guess they're out
    Also did a search but only found 1 beamshot
    What I also need is the max lumens the El Capitan puts out for the no QTC version
    Does anyone have any other recommendations? Has anyone tried a HDS light with 2AA battery tube?
