Lenses for Luxeon STAR LEDs
Ocelot
Corvallis, Oregon
Hi All,
I am interested in finding a particular lens for use with Luxeon STAR leds.
I have purchased a number of 5W Luxeons (Lambertian) and have made some headlights out of them.
When it came to lenses, the first place I bought lenses from (the smaller ones) seemed to have a poor radiation pattern. The lens was the one which Lumileds sells.
I talked with a guy from Future Electronics abuot it and he said that was because the lens was for a low dome emitter, and that Lumileds didn't have one for Lambertian emitters.
I then bought some of the Fraen lenses: The small (19mm) narrow and medium, and the larger (27mm) narrow and medium.
All seem to work pretty well except the 27mm narrow; it has a pretty nasty hole in the middle of the pattern. If I remove the lens from the housing and reposition, it looks better.
Anyway, my main question. I also scavenged a 19mm lens from an original 1W Luxeon Star/O and tried it with the 5W lambertian. The patter is square (from the fact that there are 4 substrates in the 5W LED), but the square is quite bright and is actually a very nice beam. It's obvious that the lenses which are available in the Star/O devices is different than all the others.
Does anyone know where I can get any of these lenses?
Thanks,
Scott
darkzero
Flashaholic* ,
SoCal
If the collimator that came out of your star/o differs from the one that you got from Lumileds (NX-05), you were lucky to get a NX-01.
The NX-01 is my preferred/favorite optic for it's size, even over the Fraen-LP. The NX-01 was also made by Lumileds but is no longer made. As far as I know no one sells NX-01s anymore. Most likely the only way you find them these days are in star/os (but not all have them) or if someone sells them here. Every star/o that I've had I was unlucky and got NX-05s with them.
Does the collimator in question look like these? (sorry not a single one is for sale)
(all NX-01s with a Fraen-LP sitting on the right)
(Left: NX-01, Right: Fraen-LP)
(Left: NX-01, Right: NX-05)
B@rt
Land of Tulips and Philips
Hi Ocelot,
welcome to CPF. /ubbthreads/images/graemlins/grin.gif
/ubbthreads/images/graemlins/wink.gif
If you are looking for the NX05 optics, dat2zip has them here in his Sandwich Shoppe .
btw, they are not lenses, but collimators or optics. /ubbthreads/images/graemlins/wink.gif
Ocelot
Corvallis, Oregon
You are right, the optics are NX-01. Very nice pics by the way! How did you get hold of so many NX-01 lenses?
The beam the NX-01 puts out is SO much better than the NX-05 it's surprising that they switched.
Like I said in my original post, the LED guy from Future Electronics said that the NX-05 was optimized for the batwing (low dome) LED vs the lambertian LED, and he didn't like the NX-05 either. So, I ended up ordering the Fraen narrow beam lens. It's better than the NX-05, but not the NX-01.
Thanks for the information!
Scott
darkzero
Flashaholic* ,
SoCal
No problem Scott. I found them here and there in the B/S/T forums. You just have to watch for em'.
Actually the NX-01 was designed for the batwing as well but as you know it works excellent with the lambertians. The Fraen-LP is the best collimator your gonna find (next to the NX-01 IMO) for HDs for optics of this size.
If you space the NX-01 out a bit from a 1W/3W HD emitter it will eliminate the the square hotspot giving you a nice round hotspot. Some say it might be a bit dimmer but I can't tell. Never did a comparison of them together. I don't know how it will affect a 5W though.
soloco
Honolulu, HI
This is the first time I've seen the optics so close. It looks like these lenses use the reflective AND refractive properties of the acrylic. Is that true? I first thought the NX and Fraen optics only use the internal reflections to collimate light.
Aten_Imago
Banned
Maryland - USA
Re: Optics for Luxeon STAR LEDs - NX-01
Humn
I'm a newbie so I'm not 100% sure but the optic on this Vortex 1W looks exactly like the NX-01. Nice tight focus and bright for a $50 2cell Luxeon LD
