We've seen a decade or so of usability, but only if properly stored.
That basically means stored at not too low nor too high of a voltage, and under cool temperature conditions. If you are uncomfortable, so are they. The cells you are using are used, and of course the typical go/nogo factor is if they won't hold 80% of their rated capacity - recycle and replace.
On this forum we've gone into great lengths about the "perfect" voltages to store at, storing in a fridge in a ziplock baggie, allowing them to come up to room temp before opening the baggie and subsequently recharging etc etc.
But if one is seeking long-term storage at the most perfect voltage, if a prepper-incident, happens <grin>, then that cell may not have enough capacity to do anything useful.
So a compromise is reached between perfect storage conditions, and having more available capacity when it is truly needed.
For us, that would be about 60-80% charge capacity when stored as the compromise. We've got plenty of nifty chargers that we can test cell capacity first, and then make measurements as to how long to get into this range.
But what do we tell our neighbors who think we are kind of weird anyway?
Watch as eyes glass over when you get into it..
Many neighbors right now are maintaining lawns and using other li-ion tools to do stuff in the summer. But what about wintertime when these tools are put away? Give or have them buy an Xtar or similar? Nice but not realistic.
So just simplify it greatly. Tell them to recharge their tools to full. Then when charge is finished, have them pull the trigger or whatever mechanism it is to just spin for a minute or two. This is simply to get the charge away from the top end before storage. Then, simply advise them to not leave the battery hanging in the garage - take it inside - just to minimize the heat issue. The addage "if you are uncomfortable, so are they".
Applies to cell-phone / usb charger packs too. If they only use it on vacation, and don't plan on using it very often, charge to full, and then take it off the top by charging something up one time - or just a little bit. They'll still have enough left in a REAL emergency.
That's about as much as they can take. Get the cells off the very top, and keep them cool before the next building / maintaining season begins. Keep it super simple.
But yeah, for us it is a different story with all our nifty measuring tools. Perhaps buy new cells, validate their capacity and performance, and store at the perfect voltage (representing about 30-40% capacity), and keep an eye on them as time passes.
