Prometheus
Results 1 to 2 of 2
Thread: What LED strip is this.?
    Default What LED strip is this.?
    I did bought a sequential LED DRL strip.
    https://www.aliexpress.com/item/3297...45694c4dX0pVpG
    The description says it uses LED 2835 SMD and 12V.
    1 of the strips don't work well and I would like to replace it whit a new LED strip.
    My problem is I don't know what kind of LED strip it is,
    when I search for LED 2835smd then I can only find those whit 2 pin.
    The LED strip that don't work so well have 7 pin.
    Does that LED strip whit so many pins have a special name.?
    Where do I find a LED strip whit so many pins.? (It don't have to be dual LED.)
    [IMG][/IMG]
    Default Re: What LED strip is this.?
    Quote Originally Posted by honk View Post
    [IMG][/IMG]
    I'm not sure what you are asking exactly, but that whole strip is a custom design essentially. The multiples of pins are used to create the sequential lighting of the amber/orange LEDs. I think it would be easier to simply replace the entire set, not just one led strip due to the way it functions. You didn't say which color is "not working" or HOW it is not working...just not turning on as it should? Are you familiar with the way it is intended to function?
