Jetbeam
Results 1 to 6 of 6
Thread: Headlamp for reading
    Default Headlamp for reading
    Iím looking for a budget friendly headlamp, ~$25 or less, to use for reading. For example, reading in bed when a lamp is needed or reading outside when itís still a little dark. Iíve read some of the older threads and zebralight was highly recommended but Iím looking for something less expensive. Thanks!
    Aug 2017
    Default Re: Headlamp for reading
    The Zebralight H503c or H503w would definitely be the very best option because it is a true mule as there would be no visible hotspot on the paper, and there are many low modes to choose from. I don't know of any other lights that offer these two qualities, which i think are important for reading.
    But for less, I'd say the Thrunite TH20, Manker E03H or E02H are decent budget options. I would recommend adding some adhesive diffusion film called DC-Fix to the lens to even out the beam.
    Right-angle is the right angle!
    Nov 2007
    California, Los Angeles
    Manker E03 (AA) or E02 (AAA).
    Flashaholic* LeanBurn's Avatar
    Feb 2010
    Alberta
    To customize to whatever brightness you need, the near infinite output modes of the Thrunite TH20 would be my suggestion as well, with a piece of scotch tape over the lens to soften the beam.
    THRUNITE > Archer1AV2|TiS|TH20|TN4A Hi...all in neutral white
    YUJILEDS BC Series 95+ HiCRI
    > Sofirn C01|Dorcy Penlight (Yuji modded)
    XTARVC4, LCTBC500, Amaloops, 1999 MAG-LITE 2D Incandescent(glass lens) Petzl Tikkina 80L ..... E01
    Quote Originally Posted by likethevegetable View Post
    Quote Originally Posted by dealgrabber2002 View Post
    would you guys recommend the cree xp-g3 or the Nichia 219c for this purpose?
    Aug 2017
    Nichia all the way
