I have a flooded lead-acid battery I've been working on for a bit that was left idle *way* too long. Two cells were clearly bad -- I suspected shorting in one and sulfation in the other, but was guessing the shorted one likely suffered some sulfation as well from the look of it. So I poured off most of the electrolyte from those two cells (letting any particulate gunk settle and pouring off the cleanest of it for possible reuse), distilled water rinse 2-3 times to clear out some of the remaining gunk, then made a saturated Epsom salt solution, poured it in both cells, and charged overnight. Both cells showed remarkable improvement.
Here's where I screwed up, and where the question comes in: While the portion of the original electrolyte I preserved was pretty doggone clear, and the pH was still well in the range where I'd eyeball expect it to be usable, I wasn't 100% sure I should reuse it. So, I tried it out on only one of the two cells. That ended up being the heart of the problem, as I'll get to... apologies for the next overexplained bit, because I just *don't know* why I'm seeing what I'm seeing, so I don't know which details are relevant and which aren't. Apologies in advance for the super long brain dump.
So, I closed off one cell (with the MgSO4 mixture still in it). Dumped the solution from the other cell, rinsed again with distilled water twice (leaving the water in for a couple of hours one of those times before dumping it, but I didn't charge the battery during that time -- it was close to as fully charged as it could get at the time anyway, as this was right after the overnight charge), and then filled that one cell with the recovered electrolyte.
Charged it for 4-6 hours, rested it for 2, cell had dropped under 2V. (1.6, if I recall.) So I jostled the thing around a bit to reduce any stratification I was seeing from possible leftover H2O, equilibrium-charged it to try for an increase in voltage, swapped a bit of electrolyte with a bit from one of the battery's good cells -- what can I say, I was (needlessly) worried and getting a bit desperate. I mistakenly thought getting that cell up to snuff would take 4-6 hours, when it ended up taking over a day.
Eventually, the cell works fine. (Which I guess probably comes as little surprise to most here.) A day's gone by. I've slept. I give it a nice long charge, pop all the cells again, do voltage and specific gravity testing just to see if I should fix up any other cells.
...it is at this point that I realize that I don't remember which of the two cells I was working on had the MgSO4 solution removed and which still had it in it. :fail: Dumb, dumb rookie mistake. I even told myself beforehand that I should mark the cells somehow, and my brain just shook off the suggestion. "It's only two cells, for 4-6 hours; you won't *possibly* forget in that short a time..."
Like I said, I'd only saved the cleanest, clearest portion of electrolyte for reuse. And, curse my ninja solution-making skills laughing::shakehead), my saturated MgSO4 solution had come out perfectly crystal clear. So I couldn't tell the difference by looking.
So, my college-chemistry brain says, "well, MgSO4 isn't going to turn acidic with electrolysis -- the water would electrolyze before the MgSO4 did, so I should just have more concentrated MgSO4 solution, if possible at whatever heat the stuff was running, plus maybe some precipitate. So if I just test the pH of the two cells I should be able to tell which is which."
My college-chemistry brain failed me. Because *both* cells were at or right around (limitation of my test strips -- the cheapo pH meter I had wasn't cooperating) a pH of 1, which is what I'd expect of battery acid.
I secondarily want to know what was wrong with my line of reasoning about the pH of the MgSO4 (as clearly *something* was wrong), but primarily want any clever ideas you guys may have about how to tell which cell still has the MgSO4. Thought maybe a ppm tester, but my tester freaks out at even a 1:400 dilution (in distilled H2O) of both cells' electrolyte (haven't tried weaker, and not sure if it's failing to test because of a too-high ppm count or the cheap tester not liking highly acidic solutions ). Acidity at a 1:400 dilution was also nearly indistinguishable as far as my test strips went, both seemingly hovering between 2 and 3. I was thinking perhaps take a small sample of both, mix in one of the myriad of various household salts and seeing if one or the other gives me a precipitate of an Mg salt, but hadn't settled on which to use so I haven't tried that yet.
Am I barking up the right tree? Or is there another cleverer, simpler way to test this that I simply haven't come up with? I appreciate any help, y'all -- I'm *stumped*.
